Redefining Fuse Box and Labelling the Strangeness
shakotko Avatar
shakotko Paul Shakotko
Dartmouth, NS, Canada   CAN
1970 Triumph GT6+ (MkII) "Should Have Burned It"
1976 Triumph TR7 Victory Edition
1980 Triumph TR7 "Inca"
1980 Triumph TR7
Hello TR7r's.
Well, it has been some time since we last posted on "Thinking about where to start restoring the TR7" from 2020. Huge success and been driving since.(Search the forum if you are interested). Thanks to all who helped out!
We are now onto fixing relays and intermittent flashers, horn, interior lights etc.
Wondering if you folks could help identify/confirm the 9 relays/switches in the dash?
I've labelled them 1 to 9 and have so far found them as follows on the Haynes electrical wiring diagram:
#1 Hazard Flasher Unit = #54 Haynes
#2 Headlamp Motor Circuit Breaker = #30 Haynes
#3 RH headlamp Run/stop relay = #29 Haynes
#4 Horn Relay = #57 Haynes
#5 LH headlamp Run/Stop relay = #31 Haynes
#6 Starter Relay = #3 Haynes
#7 ???
#8 Brake Light Switch = ? Haynes
#9 Nothing attached to it?
So far so good?
Relays 123.JPG    42.9 KB
Fuses 456.JPG    36.1 KB
Relays 7,8,9.JPG    35.5 KB
shakotko Avatar
1980 Triumph TR7
The Haynes materials....
E listr 2.JPG    45.4 KB
E list 1.JPG    47.3 KB
Ediagram 1.JPG    62 KB
Ediagram2.JPG    64 KB
shakotko Avatar
1980 Triumph TR7
And the overview diagram of where most of this is located.....
Overview .JPG    51.6 KB
ozkippy Michael Kip
1976 Triumph Stag "Staglet"
1979 Triumph TR7 "Empress"
Judging by the fuses yours is late vehicles US model.
This is out of the Repair Operation Manual if that's of any help.
Michael
In reply to # 1948314 by shakotko And the overview diagram of where most of this is located.....
16752004991206206249795734661995.jpg    27.3 KB
shakotko Avatar
1980 Triumph TR7
Hello Micheal.
Thanks for sending the diagram. Yes, that is the fuse box.
Would you have a diagram for the relays behind the steering wheel?
1974 Jensen Healey "Rusty"
#9 is the original turn signal flasher unit.
The original hazard flasher unit is #1.
It appears that #9 (original turn signal flasher) died and was replaced by #7, which is a generic 2 pin flasher unit from an auto parts store. This would explain why no wires are going to #9, as the wires have been rerouted to #7.
1974 Jensen Healey, now assembled and awaiting startup. =:-)
shakotko Avatar
1980 Triumph TR7
Hello Vance.
Yes, I think you have nailed it.
I bunch of these relays are intermittent and I don't love the original fuse box location. So going to move the fuse box inside the glove box so there is enough room for my big fingers smiling smiley
shakotko Avatar
1980 Triumph TR7
Hmmmm, this is what happens when it is minus 10 outside and curiosity on our minds: Pulled the floor and dash.
If we are going to fix the wiring and fuse box, may as well be suresmiling smiley.
Lots to work on: Good chance to clean out the pinecones, mouse crap, and explore a mysterious blue wire mashed into a connector and then used somewhere in the engine bay. Also, going to wire in a proper stereo with tweeters, door speakers and a subwoof under the seat. Going to clean up the carpets and try dying them back to blue much like R Truett did in part 11 of "Project TR7 shifting priorities".
If anyone has advice please chime in.
In your humble opinion, would you put down additional sound proofing before reinstalling the carpet? is it worth it?
Strip1.JPG    57.2 KB
strip2.JPG    53.8 KB
Strip 3.JPG    54.2 KB
Bluewhat.JPG    37.8 KB
ozkippy Michael Kip
I reckon the Jlue wire mashed into the connector to a Green wire is to power something only when ignition goes on with the key. Almost OEM quality in that connection it must be said. winking smiley)
Michael
In reply to # 1948573 by shakotko Hmmmm, this is what happens when it is minus 10 outside and curiosity on our minds: Pulled the floor and dash.
shakotko Avatar
1980 Triumph TR7
Continuing to sort out some mysterious wiring. Seems its previous life(s) saw some splicing of turn signals and wipers switches.
Curious is anyone know what the two wires to the left of the steering column do? Black orange and Black Green.
Found them on the wiring diagram as #38 door switch and #39 Key Switch.
IMG_2704.JPG    31.1 KB
IMG_2705.JPG    67.1 KB
shakotko Avatar
1980 Triumph TR7
If folks are curious, we put down a layer of sound barrier under the carpets. Rather easy to order (3 days from amazon.ca) and easy to install (2 hours). We preheated/warmed the sheets which made smoothing them out much easier.
Then pulled wires for future door speakers, dash tweeters, rear speakers and a small subwoofer.
Micheal, you'd be happy to know that we've sorted out the Rogue blue wire and restored to OEM standardssmiling smiley
underlay 2.JPG    53.8 KB
Underlay1.JPG    52.6 KB
BG Dave Avatar
BG Dave Dave G
Bright's Grove, ON, Canada   CAN
In reply to # 1948928 by shakotko Curious is anyone know what the two wires to the left of the steering column do? Black orange and Black Green.
Paul, the two switches work together to cause the buzzer to buzz if the key is in the ignition and you open the driver's door to leave.
Cheers, Dave
shakotko Avatar
1980 Triumph TR7
Thanks Dave. The buzzer is unhooked and not really needed at this point, so will leave the wires "as is".
Dash is now back in, carpets complete, and new LED bulbs in the console. Will test run tomorrow night.
BG Dave Avatar
BG Dave Dave G
In reply to # 1949576 by shakotko Thanks Dave. The buzzer is unhooked and not really needed at this point, so will leave the wires "as is".
Sounds like you've been busy. Good luck with the test run!
about 3 weeks and 2 days later...
shakotko Avatar
1980 Triumph TR7
While not directly related to wiring, we decided to re and re the front end with new bushings and ball joints.
The picture tells the story between the old sway bar bushing and the new one.
Hope to reduce some of the 90kph steering wobble that we all know and dislike smiling smiley
IMG_2924.JPG    41 KB
1968 Triumph TR250
