Aftermarket Custom Made Fuse and Relay Setup.
malbaby Avatar
malbaby malcolm baker
kyabram, Australia   AUS
I am interested to see what members have done as non factory.
ed.h Avatar
ed.h Silver Member Ed Hollingsworth
Omaha, NE, USA   USA
This is one in my 74 TR6. Five or so years down the road, ti's still working OK.
It normally has a cover over it.
Ed
For just a little more, you can do it yourself!
tr6harris Ken H
Oxnard, CA, USA   USA
malbaby Avatar
Thanks Ed...that's a very comprehensive set of relays and fuses.
And a custom made wiring harness?
In reply to # 2048102 by ed.h This is one in my 74 TR6. Five or so years down the road, ti's still working OK.
Ed
ed.h Avatar
Omaha, NE, USA   USA
In reply to # 2048110 by malbaby
Yes. It's similar to the stock harness, but includes a few added circuits plus explicit ground wires for most loads.
Ed
Gibber283 Avatar
Gibber283 Gold Member Randolph Gibson
Smyrna, GA, USA   USA
Good morning,
I have a 71 TR6. I just purchased an aftermarket fuse box by Classic-Technologies. I did quite a bit of research before buying. This fuse box is outstanding and very well engineered. It is more compact than some of the others on the market. It will fit in the space where the OEM fuse box went. It has 15 fuses, 7 relays, and 2 flashers all built into the board. It has 2 relays for the headlights (1 for high beam and 1 for low beam), ignition, heater, electric fan, starter, and horn. Check them out, it’s Classic-technoligies.com. I couldn’t recommend them more highly.
I also bought a new wiring harness. This is an exact replica of the OEM harness. Complete with all connections. I got it from Accusparks. They are in the UK. They make the harnesses for Moss and British Wiring. If you call them directly it will save you a bunch. I got mine for about $300. Moss charges $700. Good luck!
Randy Gibson
Atlanta, GA
  Carma and tr6harris thanked Gibber283 for this post
wake74 Glenn wake74
Raleigh, NC, USA   USA
In reply to # 2048110 by malbaby Thanks Ed...that's a very comprehensive set of relays and fuses.
Ed
And as always, Ed, your attention to detail right down to how your finished your wire bundle covering ends is second to none. I still go back your web-site years after my restoration to look a photo occasionally.
HuhReally Craig Kenyon
Phoenix, USA   USA
I have a hybrid system. A slightly modified new OEM harness with auxiliary harnesses for specific purposes. At the left corner is a sealed fused relay box from a aftermarket Jeep supplier. It has a master fuse and a direct wire to the hot alternator post. The relays are triggered by OEM high beams, low beams, horn (for the extra two horns), running lights (to turn on driving lights), and the electric fan (always powered - runs after shut down ). Another harness that is master fused and is pulled in by the ignition (coil) power. It powers ECU, HP fuel pump, O2 sensors, stereo, stereo amp, power outlet, crank fired ignition, ignition coil pack. That is powered by heavy . direct wire to large spade on battery cable which continues to hot alternator post.
IMG_8073.jpeg    35.4 KB
IMG_8074.jpeg    61 KB
w147ik Avatar
w147ik Heinrich Koncki
George, Western Cape, South Africa   ZAF
1971 Triumph TR6
2001 BMW Z3 "Wife's Car"
Six circuit blades fuse box with additional feeds for the electronic fuel injection, electric fan and driving lights and also for electric windows.
Modern relays for hooter and overdrive.
More relays for the fuel injection ECU. (out of sight)
Relays for the headlights low and high beam. (out of sight)
Edited 1 time(s). Last edit at 2024-06-09 02:50 AM by w147ik.
IMG_6973.jpeg    58.6 KB
IMG_6976.jpeg    77.1 KB
IMG_7177.jpeg    54.4 KB
malbaby Avatar
Hello Heinrch...what are you planning for protection from water ingress for the circuits below the grill.
In reply to # 2048300 by w147ik Six circuit blades fuse box with additional feeds for the electronic fuel injection, electric fan and driving lights and also for electric windows.
malbaby Avatar
Thanks guys...some great ideas above.
w147ik Avatar
1971 Triumph TR6
Thanks for that question Malcolm. I nearly forgot the small splash plates I made yesterday and laid them out in the sun to dry. Brought them in after dark.
Winter is here and we had a week of strong rain. Now all is soaked and paint dries very slow.
The splash plates protect the relays and the harness is watertight.
Edited 1 time(s). Last edit at 2024-06-10 01:30 AM by w147ik.
IMG_7179.jpeg    52.4 KB
1975 Triumph TR7
