Spitfire Master Cylinder brake line orientation
mrblimp Avatar
mrblimp Louis Mauriello
Woodmere, NY, USA   USA
Not sure how these cars are configured or if the PO did the pluming correctly.
Which port (front or back) goes to the front brakes and which goes to the rear brakes?
Andy-Sherry Avatar
Andy-Sherry Silver Member Andy Martin
Portland, OR, USA   USA
Back is for the rear
Andy&Sherry
1974 Spit 1500 Carmine Red
Always learning something
Walla Walla, WA, USA   USA
They changed over the years.
Dan Aycock
Walla Walla, Wa.
Yellowhawk Valley Spitfires
TRF# 006047
brake line comb.jpg    63 KB
Manana Avatar
Manana Steve Wten
Thornhill, ON, Canada   CAN
This is not conclusively published in any publications I've seen.
Some time ago I tried to get the group here to have a look at their systems and report back so we could get a consensus.
http://www.triumphexp.com/phorum/read.php?8,1381974,1382156#msg-1382156
I was really disappointed in how few people took the 5 minutes to check and report back, especially on such an important and undocumented item.
Anyway, my conclusion looking at the physics and limited replies is that...
Big Cap MC – Front Reservoir to Front Brakes
Small Cap MC - Front Reservoir to Rear Brakes
Edit:typo
Steve
https://stevew10.wixsite.com/spit16
Edited 1 time(s). Last edit at 2017-03-15 09:56 AM by Manana.
mrblimp Avatar
In reply to # 1441890 by Manana This is not conclusively published in any publications I've seen.
My car is a 69 Mk3 currently has a Big Cap but I know the PO installed it so I am not sure if that is what should be in the car. I can't get to it right now - rock hard snow surrounding it, but as soon as I can I will document how it is presently configured.
Falkon Avatar
Falkon Al Martin
Appleton, WI, USA   USA
On my '71, '72, and '73 the front, large reservoir is for the front brakes. They changed in later years.
mrblimp Avatar
In reply to # 1441906 by mrblimp
My front master cylinder port goes to the front disk brakes and rear port to the rear drum brakes.
Falkon Avatar
Falkon Al Martin
Correct
SexyBeast Avatar
SexyBeast Greg N
Charleston, South Carolins, USA   USA
Are the fittings the same on the early and late master cylinders?
My car is a modded Mk 2 with a later style MC and steel brake line run through a hole drilled and epoxyed through the frame and crossing about an inch away from the exhaust pipe (my Toyota engine has the exhaust is on the wrong side). Boy, is it rusty where the heat has cooked it, the brake line metal is flaking away. I would prefer to get the Mk 2 copper nickel kit, but will the fittings work on the later MC?
thanks (now I am curious about which line is going where, but I can't look, the car is crammed way up under the workbench and the hub is all torn apart)
Manana Avatar
Manana Steve Wten
Greg I haven't seen images of the two kits, however, if memory serves.....
Although line diameter is the same size, I'm pretty sure it was the front lines that had larger fittings on them, likely to avoid having them crossed either at the factory or even later. And, again, if I recall, that was the same for both Big Cap and Small Cap MCs, so naturally they would need to be reversed if you change between the two.
When I got my car it was the opposite of yours, the PO had replaced the newer MC with an older version and I think altered the lines accordingly because I remember having to reverse them when I got a new MC.
With my Engine Swap the lines also got pretty close to the exhaust. This year I'll be redoing the lines to a more hospitable route and eliminating the PDWA.
We did my brother's 240Z last summer and with the copper nickel lines and sweet flare tool from Eastwood, it went very well. (on sale now too!)
Steve
1981 Triumph TR7 Drophead
