brake master cylinder
Posted by Andy-Sherry
Portland, OR, USA
Topic Creator (OP)
Mar 27, 2011 11:45 AM
Top Contributor
Joined 16 years ago
I was looking on e bay and there is a master cylinder thats for a 1975 to 1980 spitfire,what is the difference between
that and 1 for 1970-1974.Our two spitfires a 74 and a 77 the master cylinder on both look identical.Just had another look the 77 seems a bit smaller?
Regards Andy&Sherry
Regards Andy&Sherry
Mar 27, 2011 11:50 AM
Joined 15 years ago
hunttriumph1500
Stephen Hunt
East Hampton, CT, USA
1967 Triumph Spitfire MkIII "Oldest Spitfire Owned"
1968 Triumph GT6 MkI "First Triumph!" 1971 Triumph Spitfire MkIV "Parts Car" 1971 Triumph Spitfire MkIV "Junk Yard Dog" & more |
Mar 28, 2011 09:55 AM
Joined 16 years ago
The difference between brake master cylinders is:
70? -75 large cap dual reservoir North America/USA
76-80 small cap dual reservoir North America/USA
Most everywhere else had a single reservoir, in other words the reservoir served both the front and back brakes without a seperation divider inside.
The North America version had a wall inside the master cylinder so that if the front brakes leaked out the rear would still have fluid, that is why they also have the PDWA switch.
Quote:
"I think the threads are different. The 74 has imperial and the 75 and beyond has metric."
The threads were not different between my 1974 spit and my 1975 spit, they used the exact same Master Cylinder.
Edited 1 time(s). Last edit at 2011-03-28 10:31 AM by hunttriumph1500.
Mar 28, 2011 10:11 AM
Joined 26 years ago
racer490
Jerry Bryant
Mar 28, 2011 12:17 PM
Joined 16 years ago
Mar 28, 2011 12:31 PM
Joined 15 years ago
Thanks Stephen and Mark, My bad.
I was looking at Rimmers site and apparently some but not all of the later
Master Cylinders had metric fittings. Maybe we should start a poll to find
out, so far none have metric. So I wonder, are the two styles interchangeable?
Can I take a master cylinder with a small cap and replace my large cap master
cylinder?
cylinder?
Mar 28, 2011 12:40 PM
Joined 26 years ago
hunttriumph1500
Stephen Hunt
Joined 16 years ago
In reply to a post by trzavie
cylinder?
cylinder?
I have, I put a small cap in place of a large cap, but while the fittings were the same I had to make a small modification to the bulkhead/firewall for the small cap as it's housing was like an extra 3/4" to 1" longer than the large cap style or something to that effect.
Mar 28, 2011 12:47 PM
Joined 15 years ago
Thanks guys, you are the best. So Stephen, is it the plastic housing that hits?
If so could I take a new small cap master cylinder, remove the plastic fluid
housing and put on my old large cap housing? Would there be a clearance issue
then?
Al
then?
Al
Mar 28, 2011 01:04 PM
Joined 26 years ago
hunttriumph1500
Stephen Hunt
Mar 28, 2011 01:12 PM
Joined 16 years ago
Mar 28, 2011 01:54 PM
Joined 15 years ago
racer490
Jerry Bryant
Mar 28, 2011 05:44 PM
Joined 16 years ago
Portland, OR, USA
Topic Creator (OP)
Mar 28, 2011 06:56 PM
Top Contributor
Joined 16 years ago
