brake master cylinder
Andy-Sherry Avatar
Andy-Sherry Silver Member Andy Martin
Portland, OR, USA   USA
I was looking on e bay and there is a master cylinder thats for a 1975 to 1980 spitfire,what is the difference between
that and 1 for 1970-1974.Our two spitfires a 74 and a 77 the master cylinder on both look identical.Just had another look the 77 seems a bit smaller?
Regards Andy&Sherry
trzavie Avatar
trzavie Al S.
Vast, Midwest, USA   USA
I think the threads are different. The 74 has imperial and the 75 and beyond has metric.
hunttriumph1500 Avatar
hunttriumph1500 Stephen Hunt
East Hampton, CT, USA   USA
1967 Triumph Spitfire MkIII "Oldest Spitfire Owned"
1968 Triumph GT6 MkI "First Triumph!"
1971 Triumph Spitfire MkIV "Parts Car"
1971 Triumph Spitfire MkIV "Junk Yard Dog"    & more
The difference between brake master cylinders is:
70? -75 large cap dual reservoir North America/USA
76-80 small cap dual reservoir North America/USA
Most everywhere else had a single reservoir, in other words the reservoir served both the front and back brakes without a seperation divider inside.
The North America version had a wall inside the master cylinder so that if the front brakes leaked out the rear would still have fluid, that is why they also have the PDWA switch.
Quote:
"I think the threads are different. The 74 has imperial and the 75 and beyond has metric."
The threads were not different between my 1974 spit and my 1975 spit, they used the exact same Master Cylinder.
Edited 1 time(s). Last edit at 2011-03-28 10:31 AM by hunttriumph1500.
It's reported that some late cars had metric fittings. My 1980 1500 brake system does not have metric fittings.
racer490 Jerry Bryant
Palm Harbor, USA   USA
Not sure about the threads but the nuts are standard not metric on my June 1980 Spit.
trzavie Avatar
trzavie Al S.
Thanks Stephen and Mark, My bad.
I was looking at Rimmers site and apparently some but not all of the later
Master Cylinders had metric fittings. Maybe we should start a poll to find
out, so far none have metric. So I wonder, are the two styles interchangeable?
Can I take a master cylinder with a small cap and replace my large cap master
cylinder?
Al,
It might be worth an email to Rimmer to ask what the difference is between the two brake m/c. Maybe the cylinder diameter changed?
In reply to a post by trzavie Thanks Stephen and Mark, My bad.
cylinder?
I have, I put a small cap in place of a large cap, but while the fittings were the same I had to make a small modification to the bulkhead/firewall for the small cap as it's housing was like an extra 3/4" to 1" longer than the large cap style or something to that effect.
trzavie Avatar
trzavie Al S.
Thanks guys, you are the best. So Stephen, is it the plastic housing that hits?
If so could I take a new small cap master cylinder, remove the plastic fluid
housing and put on my old large cap housing? Would there be a clearance issue
then?
Al
According to Rimmer, the only difference are the fittings. The large cap m/c has Imperial fittings, while the small cap has Metric and Imperial fittings. I take it that the threads are the same, just the wrench needed changed.
Hey Al, no it was the metal part which the master clinder sits on, it is longer, Triumph made the bulkhead behind it with a deeper recess starting in the '76 year model spits.
PMC143_lg.jpg    18.6 KB
trzavie Avatar
trzavie Al S.
Thanks for the info Stephen & Mark. Once again this forum rocks!
I also read that the bracket angle was different
Andy-Sherry Avatar
Thanks everyone for the info
Andy&Sherry
1965 Triumph TR4A
