Fuse box getting hot
Posted by TominMD
tirebiter
Jeff Garber
Aug 3, 2024 08:28 PM
Top Contributor
Joined 18 years ago
In reply to # 2058430 by Oldkartracer
Just to put this in perspective, a 300 mv voltage drop across a 12v fuse is dissipating about 7 watts at 23 amps. Ever grab an old style outdoor Christmas light? I'll bet it didn't take long to look at it :<
My money is still on the fuse clips and connections.
Alan,
Would you please share the formula you used to derive 23 amps at battery voltage across the fusebox with a 300 millivolt drop ?
Oldkartracer
Alan Strihafka
St Simons Island, GA, USA
Aug 4, 2024 08:29 AM
Joined 5 years ago
In reply to # 2058657 by brucejon
I think he just fat fingered 2.3 as 23.
VxA =W
.3v x 2.3A = 6.9W which is approx 7W
VxA =W
I try to check my calculations by mentally approximating the answer. In your example, the formula is correct but the answer is 0.69W. 3x2 is 6; point3x2 is point 6.
I stand by my answer. And don't hold onto that bulb for very long!
Oldkartracer
Alan Strihafka
Aug 4, 2024 12:08 PM
Joined 5 years ago
Oldkartracer
Alan Strihafka
Aug 4, 2024 03:34 PM
Joined 5 years ago
tirebiter
Jeff Garber
Aug 5, 2024 05:49 AM
Top Contributor
Joined 18 years ago
In reply to # 2058701 by Oldkartracer
I was asking about the formula you used to determine amperage from 300 millivolts drop starting at battery voltage. I was not asking about the formula to determine watts.
VxA =W
VxA =W
Alan,
What formula did you use to get amps assuming 12V battery voltage and given a 300 milivolt drop ?
