Can’t take out master brake cylinder
Mroogs Kyle H
Phoenix, AZ, USA   USA
1976 Triumph Spitfire 1500 "Yippee"
It appears that someone installed the top bolt on my master brake cylinder backwards, so I can’t take it out. I physically cannot get the bolt out no matter how much i try. Any suggestions?
image.jpg    46.2 KB
image.jpg    43 KB
image.jpg    45.6 KB
  JDupuis thanked Mroogs for this post
wgipe Avatar
wgipe Wes G
Fletcher, OH, USA   USA
In reply to # 1924385 by Mroogs It appears that someone installed the top bolt on my master brake cylinder backwards, so I can’t take it out. I physically cannot get the bolt out no matter how much i try. Any suggestions?
Pull the bracket off of the car (4 bolts) and then remove the bottom bolt. That will allow the cylinder to move forward enough to remove that captive bolt, which is by design.
I swear, hon, this is the last thing I should need....
Mroogs Kyle H
Well, that makes a lot more sense. Thanks lol
clshore Gold Member Carter Shore
In reply to # 1924395 by Mroogs Well, that makes a lot more sense. Thanks lol
Mind that the 4 top bolts thread into a bracket inside the driver footwell that carries the brake pedal lever and pivot assembly.
When bolts are removed, the assembly will drop to the footwell floor.
And that when re-assembling, you may need a helper.
Gt-6 Mk3 Avatar
Gt-6 Mk3 Gt-6_mk3 CW
Penfield, NY, USA   USA
1971 Triumph GT6 MkIII "Sparky"
1971 Triumph GT6 MkIII "(dismantled 1996)"
1971 Triumph Spitfire MkIV "Scooter (dismantled 2001)"
1972 Triumph GT6 MkIII "(dismantled 2000)"    & more
Welcome to the club! You'll try this again, some years from now, and might do the same thing. I know I have.
J.P.Rap Avatar
J.P.Rap J.P. Rap
Mount Hope, ON, Canada   CAN
1976 Triumph 1500 "Donna"
2007 Ford Ranger
As long as only those four bolts are removed, no problem... at least on my car. In fact there are ten bolts in mine. Four on each cylinder bracket and two in the back. I had both my brackets off earlier this year and the inside plate didn't move. It was a different story the first time I did it. sad smiley
  JDupuis thanked J.P.Rap for this post
Madflyer Andrew Kilian
Fernley, NV, USA   USA
1972 Triumph GT6 MkIII "Na"
1973 Triumph TR6 "ED"
Yes I just installed brake and clutch Masters as long as you do not remove the backing plate and just run a tap to clean threads before replacing same all good. I also remounted with SS 1/4 x 28 bolts
DSCF2911.JPG    32.7 KB
In general, SS bolts are weaker than carbon alloy steel.
They are also 'softer', so cross threading can occur more easily.
There are a number of SS alloys having different characteristics, so it's worthwhile to be sure what alloy the bolts are made of.
Be prepared to pay premium prices for premium SS alloys.
1958 Triumph TR3A
