Front Disc Shield and TWS Wilwood Big Front Brake Kit
Posted by lsloth
lsloth
James Taggart
Topic Creator (OP)
Dec 4, 2025 10:12 PM
Joined 4 years ago
I am slowly putting my front end back together and it does not look like the disk shield will fit over the new rotors. Does one need to mod the shield or get different ones?
Carb-Dave
Dave Mundt
Dec 5, 2025 08:48 AM
Top Contributor
Joined 7 years ago
I guess the obvious question is what diameter are the rotors? The common big brake kit (I sourced mine from a well known source on this board) for TR8s is using modern Mini front rotors that are about 11.5" diameter. TR8 dust shields fit over those rotors (see below).
Your dust shields look to be TR7ish..not sure they they are the same size. You may need to source TR8 shields or modify your existing. I guess the 'shop' you purchased this from left that detail out??
Carb-Dave
Carb-Dave
Dec 5, 2025 12:21 PM
Joined 12 years ago
I have the TWS Wilwood kit and did need to cut some off the shields around the calipers and grind down some high spots that hit the rotor . Your shields look different than mine , no venting for cooling . You can see the air deflectors on the blue car .
I would like to hear more about the Mini rotors , what calipers are you using ?
Carb-Dave
Dave Mundt
Dec 5, 2025 02:35 PM
Top Contributor
Joined 7 years ago
In reply to # 2150708 by drtriumph
John - the kit I installed is using Wilwood Dynalite calipers - much like the other kits offered. They were of a complete kit purchased from a well known contact on this board. Known as 'Greg's big brake kit', if you search that in this forum, that should lead you to the contact info. It fit without any modifications. The rotors shown in the pic I sourced separately to match the rears, but to the same dimensions as the rotors included in the kit from a new generation Mini Cooper. I also converted to 4X100 mm hubs - done by the same guy who put this kit together.
I still have the original front rotor set from the kit I might try selling.
Carb-Dave
Dec 5, 2025 06:59 PM
Joined 12 years ago
Carb-Dave
Dave Mundt
Dec 6, 2025 03:10 PM
Top Contributor
Joined 7 years ago
about 2 weeks and 1 day later...
Dec 21, 2025 10:25 PM
Joined 19 years ago
Winston-Salem, NC, USA
Dec 22, 2025 12:07 PM
Top Contributor
Joined 20 years ago
Darth V8R
Vance Navarrette
Dec 22, 2025 01:04 PM
Top Contributor
Joined 12 years ago
In reply to # 2153014 by bowen6951
Ditto for Glen's kit. Also those shields done look like TR8 items. Thanks, Rob
Pay no attention to the man behind the curtain, folks.
I have seen Rob's car, and it is now so heavily modified that that it is a Group 44 race car in everything but name only. His recommendations should be confined to the "Triumph Performance" section!
Bowen and TR8 Todd are the maniacs of the group, like two peas in a pod. Perhaps they are identical twins separated at birth.
Just sayin'...
1974 Jensen Healey, now assembled and awaiting startup. =:-)
Dec 22, 2025 02:39 PM
Joined 19 years ago
