Fuel pump Threads
oldguy51 Frank J. Ravosa
Enfield, CT, USA   USA
1969 Triumph TR6 "Tomato"
Good afternoon . I just cant find the fittings that were in my fuel pump on my 69 2.5 TR-6 . It needs to have the flare adapter in it. I assume it NPT into the pump and the flare fitting on 5/16 fuel line threads into that . The flare fitting can and will screw all the way into the pump but wont tighten down on the fuel line. Ive tried the part stores and they are trying to convince me its (AN) . Whats the actual size and pitch. Thanks Frank
46er Avatar
46er Ralph K
Coastal, NJ, USA   USA
I recall reading on one of the forums about this; either the pump threads were to long or the flare fitting to short to seal the line.
Here is the thread, issue begins at post #24.
https://www.triumphexp.com/forum/tr6-tech-forum.2/gas-line-leak-at-the-fuel-pump.1924988/page-2
Edited 1 time(s). Last edit at 2023-07-26 01:27 PM by 46er.
Krom Avatar
Krom Gold Member Paul K
San Rafael, CA, USA   USA
Frank,
Is the pump new? Show us a photo of the pump, including the locations where the fuel lines screw in. If the pump is of the variety that has an extended boss for the threads, the original fitting for the fuel line may not suffice. Either a longer fitting, or as Ken has done, remove material from the face of the boss to get the fitting to bottom in the pump.
steveg2 Avatar
steveg2 Gold Member Steve Gerow
San Diego, CA, USA   USA
In reply to # 1986078 by oldguy51 Good afternoon . I just cant find the fittings that were in my fuel pump on my 69 2.5 TR-6 . It needs to have the flare adapter in it. I assume it NPT into the pump and the flare fitting on 5/16 fuel line threads into that . The flare fitting can and will screw all the way into the pump but wont tighten down on the fuel line. Ive tried the part stores and they are trying to convince me its (AN) . Whats the actual size and pitch. Thanks Frank
Just checked my old pump - both the input and output threads are 1/2"-20 or AN -5. Threads are not tapered.
The 5/16" flare fitting for the input should be easy enough to find at the auto parts store.
The 1/4" flare for the output see eBay link in this post:
https://www.triumphexp.com/forum/tr6-tech-forum.2/gas-line-leak-at-the-fuel-pump.1924988.1932086/#msg-1932086
Easiest move may be to order from one of the usual suppliers.
Edited 2 time(s). Last edit at 2023-07-26 11:41 PM by steveg2.
Madflyer Andrew Kilian
Fernley, NV, USA   USA
1972 Triumph GT6 MkIII "Na"
1973 Triumph TR6 "ED"
Try TRF
DSCF2994.JPG    28.5 KB
DSCF2993.JPG    22.4 KB
DSCF2992.JPG    33.8 KB
Thank you all . Its the stock pump . The feed line to the pump was bigger than the line to the carbs ????? There are no flare fittings inside the pump for the tubing to seat on . Im using the original sweep 90* on the inlet and it wont hold the tube in place . Thats why i thought "Inverted flare male adapters were used . Its the same size hole for both in and out so I made another 5/16ths supply to carbs. Having a longer fitting wont put compression on the flare . At least I was told its 1/2 X 20 so Im going to get two inverted male flare adapters. After 3 yrs. of fixing what needs fixin , Im not gonna burn her down . You guys are the best ! Frank
steveg2 Avatar
Frank,
Both fittings have the 1/2-20 threads. They're called flare fittings, but for the fuel pump, they both use compression rings: one is 5/16"; the other is 1/4".
One fitting has a 5/16" hole through, the other 1/4". The output to the carbs is 1/4" tubing. The input from the tank is 5/16" tubing.
Steve : You simply answered the question to the tee. I tank you ! I just couldnt see the seats for the compression rings and assumed I misplaced the inserts . I bought a 3/8 Thematic switch to turn on the elect fan. Wanted to use the hole on the right side of the water pump. The left side has the original temp sender. Cant find out the thread pitch on the hole either. This is the second switch Ive bought and it wont thread in either. The temp sender screws into booth holes. Ill buy a tap and clean out the threads. Frank
steveg2 Avatar
In reply to # 1986782 by oldguy51 Steve : You simply answered the question to the tee. I tank you ! I just couldnt see the seats for the compression rings and assumed I misplaced the inserts . I bought a 3/8 Thematic switch to turn on the elect fan. Wanted to use the hole on the right side of the water pump. The left side has the original temp sender. Cant find out the thread pitch on the hole either. This is the second switch Ive bought and it wont thread in either. The temp sender screws into booth holes. Ill buy a tap and clean out the threads. Frank
Frank,
The sender threads are BSPP (British Standard Pipe Parallel). I wouldn't try to re-tap them or you'll likely ruin the water pump housing. There are other non-invasive options for a fan switch:
BPNW sells a coolant pipe (lower rad) with a boss for a switch.
You can also get an upper-hose adapter (picture).
Edited 1 time(s). Last edit at 2023-07-29 08:08 AM by steveg2.
screenshot.4065.jpg    40.4 KB
Again Thank you Steve smiling smiley I will be buying one of these today from Amazon.Only because Im in Ct. and BPNW takes 7 to 8 days to get anything unless you spend three times what your purchase is . Get ready because UPS employees as of August 1st have a sizeable raise already agreed on and Im assuming all will feel the raise Frank
joemamma Avatar
joemamma Gold Member Robert White
Monroe,NC 28112, USA   USA
1970 Triumph TR6 "Memory Of Kay"
Here is my take on this problem. Dealing with the pump Moss sell they advise installing new ferrules. The ferrules Moss supplies are not as thick as originals. Not sure if that is a good description. What I ended up doing to make mine work was to take 2 ferrules and grind off about 1/4 of each piece. Then install the 2 with the ground down ends together. The fresh new ends went into the pump and screw in fitting. They crimped down fine and I have no leaks. If you have an original pump and need to replace it on the road with a new Moss pump you will have lots of trouble getting the lines to seal. I made up some new stub lines to carry in my parts kit in case I run into someone with a problem on the road. Taking some material off the face of the new pump is a great idea and I will probably do that to the new pump I carry as a spare. Always some stuff to deal with.
70 TR6 CP series PI LHD, MGBs TR8
1963 Triumph Vitesse 6
