Fuel line routing fro fuel pump.
Posted by malbaby
Topic Creator (OP)
Oct 23, 2014 09:48 PM
Top Contributor
Joined 19 years ago
millersinbsmo
Bruce Miller
Oct 28, 2014 04:40 PM
Joined 15 years ago
My tr4a runs from the fuel pump in a metal line up to the front of the head, in front of the thermostat housing (under the hose to the radiator) then ends about six inches from the carbs. Don't remember if their is a rubber tube elbow by the fuel pump or a direct connection, I current have an in line fuel filter between the hard line and carbs, you could run direct to carbs with rubber hose.
I'll get a picture or two tomorrow
Bruce
Bruce
millersinbsmo
Bruce Miller
Oct 29, 2014 02:36 PM
Joined 15 years ago
Hard line from fuel pump up to carbs with fuel hose making the end connection. Clamp secures hard line with bolt to lower thermostat cover bolt.
Can't guarantee this is "factory standard" but I would think so.
Bruce
Bruce
Topic Creator (OP)
Oct 30, 2014 12:38 AM
Top Contributor
Joined 19 years ago
Thanks for the pics Bruce.
This is what I did today.
Just for interest, the 3rd pic shows the narrow belt conversion that I am doing. [ running thermo fan set up]
Edited 1 time(s). Last edit at 2014-10-30 12:41 AM by malbaby.
millersinbsmo
Bruce Miller
Oct 30, 2014 08:40 AM
Joined 15 years ago
about 1 week and 6 days later...
about 9 months and 3 weeks later...
Rodney
Bob S.
Sep 5, 2015 09:53 AM
Joined 10 years ago
I am putting a 1964 TR4 back together and am not sure where the fuel line runs through the chassis from the tank to the pump. If somebody can help I would appreciate the help. Is steel line or braided line recommended and how long must the line be? Thank you!
Albuquerque, NM, USA
Sep 5, 2015 05:18 PM
Top Contributor
Joined 13 years ago
My 4 lines run like Bruces' and I think is stock. Mal...oh man...that looks great. You might want to keep an eye on the closeness to the exhaust manifold and the possibility of percolating your fuel causing vapor lock after you shut down though.
Steve
TR250
TR4
68 TR250
57 TR3
Both regularly driven
49 Triumph 2000 Roadster project
Steve
TR250
TR4
68 TR250
57 TR3
Trike4
Marcus G
Sep 5, 2015 10:30 PM
Joined 11 years ago
The line goes down from the tank to a hole through the frame. Mine has rubber grommets through the frame. It then bends along the frame and is clipped at several spots. It then passes through another hole in the frame and comes up to the fuel pump. It really is no where near the exhaust heat because it is outboard on the frame.
Mine had a flexible rubber tube joining the piece from the tank down to where the long piece passes through the frame. Another flexible rubber tube joining to the short pipe to fuel pump.
I replaced my aging and rusted fuel line with large brake line from an auto parts store. It was difficult to bend as needed and to still get it to feed through. I used the old fuel line as a template.
Sep 6, 2015 05:51 AM
Joined 13 years ago
Mine isn't stanchioned off on the right front side of the motor but hopefully these will help as well.
"What a filthy job"
"Could be worse"
"How"
"Could be raining"
Edited 1 time(s). Last edit at 2015-09-06 05:52 AM by dadams62.
"What a filthy job"
"Could be worse"
"How"
"Could be raining"
about 1 month and 4 days later...
Rodney
Bob S.
Oct 10, 2015 11:50 AM
Joined 10 years ago
about 9 years and 8 months later...
Jun 10, 2025 11:40 PM
Joined 2 years ago
Merlin63Tr4
D R
Jun 11, 2025 09:29 AM
Joined 9 years ago
Factory routing of fuel line from fuel pump outlet to carburetors.
D.
The first rule of troubleshooting. Never trust whoever was there before you, they couldn’t fix it.
D.
Jun 11, 2025 03:01 PM
Joined 2 years ago
