[Solved] No spark until after turning key off
Posted by Sandercohen13
Sandercohen13
Andrew Harpold
Parkersburg, WV, USA
Topic Creator (OP)
Sep 11, 2019 08:01 PM
Joined 6 years ago
70tbolt
Geoff Ullmann
Sep 11, 2019 08:18 PM
Joined 8 years ago
Sandercohen13
Andrew Harpold
Topic Creator (OP)
Sep 11, 2019 08:30 PM
Joined 6 years ago
Seemed to happen after I replaced the starter solenoid. Hard to pin point exactly because the car is a work in progress so some says when I work on it i dont start it because I am working on something else but I had the car running one day then tried to run it again then the starter solenoid went bad, replaced it then tried to start it again a few days later and nothing. The day I got it to run was its first and only day.
GottaSpit
Duncan A
Sep 11, 2019 08:47 PM
Joined 9 years ago
Have you examined your ignition switch? When I dissected mine I was shocked by the amount of black and green corrosion junk inside there. On my second spit rebuild (underway now), I just threw the old one out and put in a new one without even checking. I figure those old ignition switches are just going to be trouble sooner than later. I feel the same way about old solenoid relays. Pretty cheap to replace and a definite reliability upgrade.
Sandercohen13
Andrew Harpold
Topic Creator (OP)
Sep 12, 2019 05:11 AM
Joined 6 years ago
I'm leaning to the solenoid because the ignition switch is brand new, not to say it couldn't have failed but when I rewired my solenoid I told myself to take a picture of the former wiring and forgot so it is very possible I've wired it wrong. I'll examine it this evening. Thanks for your replies.
Sep 12, 2019 05:59 AM
Top Contributor
Joined 14 years ago
spitfire50
Paul Mugford
Sep 12, 2019 07:56 AM
Top Contributor
Joined 15 years ago
In reply to # 1647822 by GottaSpit
Duncan,
I wish you luck with this policy. Sometimes a new part will be distinctly inferior to the old one. "Pure Chinesium" ring a bell?
Good luck,
TRF# 10423
Sandercohen13
Andrew Harpold
Topic Creator (OP)
Sep 12, 2019 08:22 AM
Joined 6 years ago
Harness is not original. It is to the extent that it is a reproduction of the original though. Baught it from britishwiring.com.
In reply to # 1647868 by clshore
If switch and solenoid are good, then your wiring is not connected properly.
Assuming that harness is original, consult a wiring diagram and match the colors.
dklawson
Douglas K. Lawson
Sep 12, 2019 09:10 AM
Joined 6 years ago
You mentioned that you have replaced the solenoid. The solenoid and coil wiring are tied together a bit on a '79 and as mentioned above... you may have just put a wire in the wrong location.
See the wiring diagram linked below. The coil and distributor wiring is in the upper right corner, the solenoid in the upper left. Pay particular attention to the pink/white and white/yellow wires on the solenoid.
http://www.triumphspitfire.com/images/wiring/78diagram.jpg
Doug L.
1967 Triumph GT6 Mk1
1964 Morris Mini Cooper S 1275
Doug L.
colodad
Calvin Williams
Sep 12, 2019 10:44 AM
Joined 12 years ago
No power to coil after ignition returns from start position ?
The pink should always have 8+vdc with the key on, supplies power to the coil through the W-Y.
The solenoid supplies 12vdc to the W-Y only when solenoid is pulled in, to start with more power, then when the key is released to run position that 12vdc is gone, and the 8+vdc pink feeds the coil W-Y wire.
The Pink resistor wire might be bad.
colodad
Calvin Williams
Sep 12, 2019 10:52 AM
Joined 12 years ago
this is confusing: "not spark untill I turn the key in the off position" Did U mean "on" position?
In reply to # 1647804 by Sandercohen13
Hello, my 79 spitfire has started to not spark until I turn the key in the off position. I found these results using a spark tester. Any idea as to what is going on ? Tried this at both the plug and the coil.
Sandercohen13
Andrew Harpold
Topic Creator (OP)
Sep 12, 2019 11:05 AM
Joined 6 years ago
colodad
Calvin Williams
Sep 12, 2019 11:25 AM
Joined 12 years ago
"work in progress"
"some days when I work on it I don't start it, because I am working on something else"
"the day I got it to run was it's first and only day"
you should start explaining here, "the day you got it to run", just fired then died ?, or it started and ran well ?, and what was done after that?
In reply to # 1647819 by Sandercohen13
colodad
Calvin Williams
Sep 12, 2019 11:35 AM
Joined 12 years ago
"Pure Chinesium" had to google that one, not in my dictionary. (aka inferior metal, seems to been made in China)
British Wiring, 617 Walnut St, P.O. Box 185, Bally PA. Not to say it's a bad harness, till the facts are known.
In reply to # 1647891 by spitfire50
Duncan,
Good luck,
Duncan,
Good luck,
