alternator conversion?
Posted by Dan Spitfire
Dan Spitfire
Dan Grzybek
Topic Creator (OP)
Aug 20, 2012 06:25 PM
Joined 15 years ago
hey all
so i am in need of a new alternator and have been thinking about the conversion to the ac delco unit as described by paul tegler on his site.
paul tegler alternator conversion
anybody else done this? looks like it is very straight forward of a swap. only have to fab part of an upper bracket, doesnt seem real hard, and splice in a new wiring. any pics would be great...
very cheap in comparison with alternators for the triumph and much more readily avaliable. just wondering if any body has done it here following what was outlined and if there were any other concerns with going up to a 55 amp alternator.
thanks...
Dan Grzybek
1976 Spitfire "The Mistress"
Buffalo, NY
thanks...
Dan Grzybek
Buffalo, NY
cokerart
Bob Coker
Warner Robins,, GA, USA
1950 MG TD "Esme"
1963 Triumph TR4 1971 Triumph GT6 MkIII 1973 Triumph GT6 MkIII "Spit-6 Or Dr. Frankenstein" & more |
Aug 20, 2012 06:33 PM
Joined 17 years ago
This has been discussed numerous times on this forum. You might want to search the postings. I went with a Ford Fiesta (1980) Bosch alternator that almost literally "dropped in" and accepted the OE Triumph alternator plug.
“The English never draw a line without blurring it.”
-Winston Churchill
-Winston Churchill
Dan Spitfire
Dan Grzybek
Topic Creator (OP)
Aug 20, 2012 06:36 PM
Joined 15 years ago
id be interetsed in hearing about that one ive never heard of that conversion... id be more inclined to do that one as my one hesetation has been cutting and splicing wires... figured they dont need to be cut and spliced any more
Dan Grzybek
Buffalo, NY
Dan Grzybek
Buffalo, NY
Aug 20, 2012 06:42 PM
Top Contributor
Joined 14 years ago
I also have a bosch 75amp. I had to make a new upper adjusting bracket, that was it. I got a chrome bracket from the local auto parts store. It said " early Chevy or universal" on the package, and was about 2 feet long so I had to cut off 18 inches.
'S all for now
Vic
'S all for now
Vic
fuzzy thanked carChips for this post
1968triumphgt6
Louis Boudreault
Aug 20, 2012 06:55 PM
Joined 15 years ago
Hi Dan, I did the switch to the AC Delco unit last fall. I just followed Paul Tegler's procedure. Very easy. Had to get a couple of large nuts and bolts to secure the alternator, but that's about it. I used the same bracket that supported the old generator. Nice DIY project.
cokerart
Bob Coker
1950 MG TD "Esme"
Aug 20, 2012 07:08 PM
Joined 17 years ago
I recall that I had to grind about 1/8" off of the cast iron bracket to allow clearance of the alternator. I used the adjusting bracket that came with the car. (Who knows if THAT's original???)
-Winston Churchill
hymodyne
james king
Aug 21, 2012 04:12 AM
Joined 16 years ago
+1 on the chevy alternator swap. I went to my local auto parts store and bought the 1978 chevy camaro alt and nearly doubled my output, from 37 amps (lucas) to 63 with the GM alt. easy swap with a little modification of the mounting bracket.
James
Edited 1 time(s). Last edit at 2012-08-21 04:14 AM by hymodyne.
James
Aug 21, 2012 07:48 AM
Joined 13 years ago
Its way too much amps and the coil will fry if you don't knock it down to about 3 amps at that point. why would you need that much electricity?
Well I can see we've all got a big charge out of this thread so I see all the pictures but I still like mine the way it is. Some people blow them out with an air hose and lube them. Tighten the screws. Paint it, even. As long as it makes it run. Sounds like AC D got the most votes for those with a conversion but you don't hear about too many people switching from a generator because you can always push start the car even if it has only 6 volts on the battery where as an alternator needs almost the full 12 or its happening. And the idea is to not make you walk.
Edited 1 time(s). Last edit at 2012-08-26 06:24 PM by 69MkIII.
rhodyspit75
Ernie Connor
Cumberland, RI, USA
Aug 21, 2012 08:01 AM
Top Contributor
Joined 16 years ago
Darrell, the alternators job is to charge the battery. You can't knock down amps. The larger alternator will charge the battery quicker and keep it charged while you are drawing a lot of current. Like when you have all the lights, radio and heater blower on at the same time. An alternator upgrade will have no effect on the coil. The only recommendation I would make would be to increase the size of the wire from the alternator to the solenoid if you often run a lot of current suckers. BTW I have the delco and did not change the wire and have no problems. Ernie
Ernie
1975 Triumph Spitfire
Ernie
triumphguy
Dave Roberts
Loveland, CO, USA
Aug 21, 2012 11:12 AM
Joined 15 years ago
I did this swap to a 1500 I owned about 20 years ago. Easy and cheap! Tho sorta unrelated, I swapped in a 140 amp alt (from a Caprice) onto my brother's '72 Chevy truck. The original setup had the external regulator and an output of about 20 amps. He gave me a call when got home afterward. He was exstatic that his headlights didn't dim evertime he stopped at a traffic light. The Delco alt swap is the way to go!
wildwood
Rick Howe
Aug 21, 2012 11:44 AM
Joined 14 years ago
spitfire50
Paul Mugford
Aug 21, 2012 07:29 PM
Top Contributor
Joined 15 years ago
In reply to # 837031 by rhodyspit75
Hi,
I recommend increasing this wire anyway. You don't need a lot of "current suckers" to overload this wire, just a dead battery. When the alternator charges a dead battery it will send a lot of current through this wire.
TRF# 10423
1968triumphgt6
Louis Boudreault
Aug 21, 2012 07:55 PM
Joined 15 years ago
Aug 21, 2012 08:08 PM
Joined 15 years ago
