Best Tyre on 5.5" 14 inch Wheels?
talete76 Myriam Italy
Alba, Piedmont, Italy   ITA
In reply to # 950228 by Spitified
In reply to # 949668 by ham204 What is the best combination of tyre on a 5.5" wide 14 inch wheel without modifications to the body? I was thinking 165/60 - is that about right?
You could go as wide as 175 I think with the right offset rim. Do you know if your offset is at least +22mm? Paul Geithner on his website runs a 185/55/14 set up on a 6" wide wheel with a +26 offset, and he has a lowered suspension and he has no problems. I would think 60 would be fine since you don't plan on lowering it.
Dear Spitfied, I see you reason on offset and so I think you're the right to whom I can ask form my doubt:
I would like to put under my spitfire '76 four 175/70/13 on a 5,5" dunlop D1 replica wheels that have an offset ET16 (+16mm).
I've found that in origin the spitfire has an offset of +0.5" (+12.72mm) do you think that an offset of +16mm should be ok?
Thank you for your attention!smileys with beer
280Z Turbo Avatar
280Z Turbo Sean W
Zeeland, MI, USA   USA
Slightly off topic, but where do you even find 14" wheels for the Spitfire now?
TheFlash300 Avatar
TheFlash300 Dave Gutknecht
http://www.vtowheels.com/Classic-8-Wheel-14-x-55-Silver-With-Machined-Lip-4-x9525mm-22mm_p_357.html
In reply to # 1533120 by 280Z Turbo Slightly off topic, but where do you even find 14" wheels for the Spitfire now?
Sorry of being off topic but I've searched about wheels and I saw there that the user Spitfied talked about offset!
I found also some pages in which I can simulate different offset but I know that those application have a margin of error, so it's better if someone have tried with offset ET16!
