Pace Setters Header & frame Clearance
TDSpit Silver Member Charlie Bunnell
Crossville, TN, USA   USA
1952 MG TD "Chitty Bang"
1976 Triumph 1500 "DOA"
It's a '76 Spit 1500. When buying a car, even a basket case, I don't generally check the header clearance from the frame. Well I just discovered the "pipe" from the #1 cylinder is rubbing against the frame. So when installing a Pace Setter 70-1090 header, does one usually "adjust" the frame with a grinder to provide the necessary clearance? Or is there a more sinister gremlin here?
Charlie B.
20180613_212854.jpg    45 KB
20180613_193813.jpg    55.1 KB
bonnett1954 Avatar
No gremlins. Looks to be ground already. Might as well grind a little more to make it fit.
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
That's a cut out for a late model catalyst, you can grind off a little frame or squeeze the header pipe a little.
'S all for now
Vic
Thanks Vic and Dave. I felt the grinder was the answer but sometimes it's comforting to received affirmation from others.
Charlie
Spitfirejoe Avatar
Spitfirejoe Joe Guinan
Fremont, NE, USA   USA
Ah, the old "Heat And Beat to Fit" headers. I run those on my 1980 and had the same issue. Grind a bit off the frame and maybe flatten the tube a bit. Different motor mounts can make the fit worse, or better.
Joe Guinan
Fremont, Nebraska
poulsbobill Bill K
Poulsbo, WA, USA   USA
In reply to # 1540573 by Spitfirejoe Ah, the old "Heat And Beat to Fit" headers. I run those on my 1980 and had the same issue. Grind a bit off the frame and maybe flatten the tube a bit.
Did the same. A little bit of both and works!!
Bill
1980 Spitfire
Thanks to all. Here's what I started with, and where I'm at now. Been a long haul but almost done. That manifold situation surprised me.
2012 when bought.JPG    60.6 KB
20180614_124941.jpg    45.5 KB
I remember those days too.
So did the neighbors.
