Handbrake failure
Andy-Sherry Avatar
Portland, OR, USA   USA
I have no handbrake and rear brakes are stuck on i will be looking underneath again
Andy&Sherry
1974 Spit 1500 Carmine Red
Always learning something
Do you mean it's like the cable snapped?
Perhaps the brake is stuck fully on?
Herald948 Avatar
Herald948 Andrew Mace
Perhaps the compensator is bound up and stuck in more or less an "on" position? Not much else that can "lock" anything on unless something hit a cable guide hard, closing it up (don't ask me how I know this can happen, say, from a broken u-joint causing an axle to flail around and smash things...). Or you have an odd hydraulic problem?
The rachet mechanism can jam and cause that.
Another cause is if the cable somehow gets fouled by something underneath that tensions it and applies the brakes.
Andy-Sherry Avatar
I pulled up at home after 2 days of driving applied handbrake,when i went to put car away there is no tension on handbrake lever,i will investigate when i get home today,oh and it ran flawlessly for almost 300 miles over the 2 days
Andy&Sherry
Andy-Sherry Avatar
All is good at the rear it is something to do with the cabin end i applied and released the brake lever and the brakes released
Andy&Sherry
In reply to # 1533432 by Andy-Sherry All is good at the rear it is something to do with the cabin end i applied and released the brake lever and the brakes released
Andy,
Could it have been a case of applying the handbrake to hot drums and not being able to release it when the drums had cooled? Then later, when even cooler, the brake had released. Good it has released now anyway.
My guess is carpet fibers in the top of the cable.
