Howl from Front End
mykeeb33 Avatar
mykeeb33 Silver Member Mike Bostwick
Puyallup, WA, USA   USA
The one that came from VB was apparently the wrong one also. The felt was glued into kind of a metal casing. Has anyone seen one like this before? What's it supposed to go in?
Edited 1 time(s). Last edit at 2018-04-27 10:58 PM by mykeeb33.
20180427_130627.jpg    40.3 KB
brucejon Avatar
brucejon Bruce Jones
Santa Cruz, CA, USA   USA
1969 Triumph Spitfire MkIII
1972 Triumph TR6
In reply to # 1529153 by Tonyfixit Hub pullers are not normally required.
If you are changing the grease seals, post here when you get the kit.
Apologies, I just did this on my tr3 where the puller is needed and claim confusion!
In reply to # 1529239 by mykeeb33 The one that came from VB was apparently the wrong one also. The felt was glued into kind of a metal casing. Has anyone seen one like this before? What's it supposed to go in?
Mike,
It is supposed to go in the inner end of the front hub. The problem is the felt is too thick and the metal is the wrong diameter. If you are reasonably careful you can save the old seal by driving it out with the old bearing. Then you can clean it and reuse it or use part of the new felt and the old metal ring.
BTW this is one case where VB isn't the one to blame. I haven't seen a new seal that fits right in decades.
TheZster Avatar
TheZster Steven Z
SAINT LOUIS, MO, USA   USA
1978 Triumph 1500 "BLK-BRY"
In reply to # 1529464 by spitfire50
Mike,
Now that's an interesting problem..... remind me to use care removing the seals......... Has anyone found an alternative that fits??
Z
I went through this last year. I ended up making my own seals from thick leather and gluing them in the original steel holders.
In reply to # 1529699 by TheZster
Z
Steven,
The Lotus guys seem to have found a normal rubber lip seal that works. One similar to the front timing cover seal for instance. I don't remember ever seeing a Chicago Rawhide or other easily cross referenced number for that seal.
TheZster Avatar
TheZster Steven Z
In reply to # 1529879 by spitfire50
Z
Steven,
Thx Paul: I better get busy looking for reference #'s.... just so I have a couple in my "parts bin"....
Z
brentb Avatar
brentb Brent Burlingham
Saskatoon, SK, Canada   CAN
Sorry for the delay in posting. I decided to take my caliper off to see if it was working OK, and one of the pistons was seized open. That's what was causing the howl. Replaced the caliper, and the problem is gone. I have parts for the wheel bearings, but will wait for a bit to tackle that job. Thanks for all the help!
Another happy ending.
Oh wait,...it cost money.
mkivmarty Avatar
mkivmarty Marty Yanik
N.E.Ohio, USA   USA
In reply to # 1533822 by Doug in Vegas Another happy ending.
Doesn't a happy ending cost extra?
Marty
Greg1835 Avatar
Greg1835 Greg S
Rudolph, WI, USA   USA
About 200 piaster 45-50 yrs. ago.winking smiley
In reply to # 1533866 by mkivmarty
Only the happily ever afters.
For the rest of us there's bailing wire and duct tape.
1980 Triumph TR7 Drophead
