Ok I’m very confused. Here’s the reason why.
With the motor out I though it would be good to clean up some dead wiring that has been hanging around since I bought the car.
The car is a 78. The previous owner had removed the original distributor (electronic) and replaced it with a Lucas 43D4 points model. I subsequently added a Pertronix and a Lucas Sport Coil.
So I wanted to remove the big plug that I guess when to the original distributor and drive resistor. This connector has one wire of white/blue, white/sliver and just white. I get 12v on the white when the key is in the run or start position.
So the Ballast wire (pink/white) is still connected to the starter relay. There is a white/yellow wire on the + side of the coil. There is a white/yellow wire connected to the same point on the starter relay as the Ballast wire. That all seems to match the diagram.
So here where I’m lost. I have 12v at the coil in run and start on the white/yellow wire. If I disconnect the ballast wire and the white/yellow at the starter relay I still get 12v on the coil. Does this mean I’m still using the ballast wire?
If so I’ve been running my pertronix and my sport coil off it for 15 years!
If this is the case it seems like I should be able to cut the ballast wire off and connect the +side of the coil to the white that fed the driver resistor right?
1978 Triumph Spitfire
Ballast Wire
Posted by Voda2000
Ballast Wire
Voda2000
Andrew McMillan
Winnipeg, MB, Canada
Apr 15, 2018 09:39 PM
Joined 1 year ago
J.P.Rap
J.P. Rap
Mount Hope, ON, Canada
Apr 15, 2018 10:13 PM
Joined 1 year ago
My 76 is wired a bit differently but that's similar to what I did. I used the white wire from the drive resistor and connected it to a ballast resistor then to the coil. I eliminated the pink wire. On my car the white to pink connection was in the wiring harness near the alternator.
Looking at the 78 diagram it looks like the pink wire feeds the white yellow wire then goes to the coil. The white yellow get 12 volts from the solenoid only when starting. If you have 12 volts all the time, something must be rewired.
Did you meter it or are you assuming it's 12 volts looking at the diagram. I only ask that because the white yellow should only get power from the solenoid when starting the car.
In reply to a post by Andrew
I would have to say no because you said you're getting 12 volts at the coil all the time.
Voda2000
Andrew McMillan
Apr 15, 2018 10:40 PM
Joined 1 year ago
Yes I did meter it. Still beeing in the shop working on it since the post.
I’m thinking the way they did the 78 was that during starting the white/yellow got 12 volts from the starter relay. Once the car starts the terminal at the relay goes dead and the white yellow draws power through the ballast wire effectively increasing the resistance.
The part I’m stuck on is would you see 12v at the coil either way? I’m thinking yes because adding resistance doesn’t change the voltage just ups the current draw but I might be wrong about that.
I also did some resistance checks. The white/yellow wire has (basically) 0 ohm. The white drive wire to the white/yellow at the coil has 1.8 ohm. Since the only way I can see the coil is powering I think it’s via the ballast wire...
The coil has 3.0 ohms across it. Does this mean the coil has a total draw of 4.8ohm? If so I’m surprised this hasn’t caused problems.
Sorry about the long posts.
Doug in Vegas
Douglas D
Las Vegas, NV, USA
Apr 15, 2018 10:50 PM
Top Contributor
![]() ![]() ![]() ![]() Joined 2 years ago
You will only read 6v at the + side of the coil when the - side is grounded.
If you are going to a 12v system you should ignore everything and tap any white wire for power.
Here are two pictures I made to illustrate the hookup on the Lucas AB-14 in both 6v and 12v.
Manana
Steve Wten
Thornhill, ON, Canada
Apr 15, 2018 11:00 PM
Top Contributor
![]() Joined 5 years ago
Our ignition systems are actually quite easy to understand if you take a few minutes to run through it.
Identifying where all your wires go or don't go is a great first step.
Understanding how the ballast wire gets incorporated into the process is a good next step.
This may help you better understand your system and to know what you should keep and what you should get rid of.
http://stevew10.wixsite.com/spit16/ballast-wire-system
All the best.
Steve
All the best.
Steve
spitfire50
Paul Mugford
Rochester, N.H., USA
Apr 16, 2018 05:37 AM
Top Contributor
![]() ![]() ![]() ![]() ![]() Joined 7 years ago
Andrew,
You can keep the ballasted ignition system. All you need to do is supply the red wire of the Pertronix from that white wire. The black of the Pertronix still goes to the coil negative and the yellow/white from the starter relay still supplies the coil positive.
Hatfield, MA, USA
Apr 16, 2018 05:58 AM
Joined 3 years ago
In reply to # 1526603 by Voda2000
Series curcuit :voltage is dropped across the resistance. Current remains the same.
Parallel curcuit: voltage remains the same for all branch's.
The current changes or splits off into the branch's. It will follow the path of least resistance.
Your ing system is a switched series curcuit. If your coil is indeed a 3ohm coil the ballast wire should be defeated.
It's starts ok? Because the coil recieives the right amount of power.
Add the total amount of resistance in the series curcuit to obtain the amount of current. 12v/4.8=2.5 amps.
12v/3=3amps. You want that missing .5 amps I think!
Most basic answer I can muster at 6am.
Edited 1 time(s). Last edit at 2018-04-16 06:08 AM by lef2wander.
Voda2000
Andrew McMillan
Apr 16, 2018 06:48 AM
Joined 1 year ago
Thanks guys.
Steve your diagram shows exactly what I was trying to describe.
James, what you said makes sense. Since it’s in series would the volt drop be measurable when the cars not running?
That’s the part that still confuses me is how when I hook my meter from the negative battery to the positive terminal on the coil I get 12v.
carChips
Victor Harnish
Kelowna, BC, Canada
Apr 16, 2018 07:07 AM
Top Contributor
![]() ![]() ![]() Joined 6 years ago
Hook your meter from the W/Y to the + at coil.
'S all for now
Vic
'S all for now
Vic
Re: Ballast Wire
#10
Hatfield, MA, USA
Apr 16, 2018 07:20 AM
Joined 3 years ago
The coil will show its maxium supplied voltage. That's why some older style EI systems burn out if the key is left on to long.
Edited 1 time(s). Last edit at 2018-04-16 07:22 AM by lef2wander.
Re: Ballast Wire
#11
Manana
Steve Wten
Apr 16, 2018 07:52 AM
Top Contributor
I read through more carefully this time; I think you've got everything correct Andrew.
From your first post...."If this is the case it seems like I should be able to cut the ballast wire off and connect the +side of the coil to the white that fed the driver resistor right?" I'd say yes and that's exactly how I did mine.
From your second.... "The part I’m stuck on is would you see 12v at the coil either way? I’m thinking yes because adding resistance doesn’t change the voltage just ups the current draw but I might be wrong about that." I think you are also correct about that.
and correct about this too...."I also did some resistance checks. The white/yellow wire has (basically) 0 ohm. The white drive wire to the white/yellow at the coil has 1.8 ohm. Since the only way I can see the coil is powering I think it’s via the ballast wire... "
Sounds like you've done some great investigation on this and I imagine you've accounted for all the wires connected to your coil, but what I don't get is why when you disconnect the ballast wire and the white/yellow at the starter relay you are still getting any voltage at the coil? Unless they are remaining connected to each other where you pulled them off.
Other than that there either must be another 12V wire to your coil, or, perhaps a PO spliced 12V into one of those wires someplace you can't see it?
Not sure if that helps.
Edit: typo
Steve
Edited 1 time(s). Last edit at 2018-04-17 08:28 PM by Manana.
Edit: typo
Steve
Re: Ballast Wire
#12
TheZster
Steven Z
SAINT LOUIS, MO, USA
![]() 1978 Triumph 1500 "BLK-BRY"
Apr 16, 2018 10:23 AM
Joined 4 months ago
IMHO... Manana ISteve) is the "go to" source for this particular electrical issue..... He got my 78 Spit running perfectly with my new pertronix system....
Pay attention to him.... or Pay to replace more ignition parts somewhere down the road....
Z
Z
Re: Ballast Wire
#13
Voda2000
Andrew McMillan
Apr 16, 2018 06:30 PM
Joined 1 year ago
In reply to # 1526630 by Manana
Sounds like you've done some great investigation on this and I image you've accounted for all the wires connected to your coil, but what I don't get is why when you disconnect the ballast wire and the white/yellow at the starter relay you are still getting any voltage at the coil? Unless they are remaining connected to each other where you pulled them off.
It actually helps quite a bit I think. You are correct I forgot to mention that they ballast wire and the white/yellow are connected to the same female spade so when I disconnected the female spade from the starter relay they are still tied together. To test to see if the PO had modified the wiring all I have to do is separate the ballast wire from the white/yellow and retest at the coil. If I still have 12v then then the PO did some "additional" wiring if not then the system has been running off the ballast wire. If it has, the amazing part is that it has been running this way for 15 years with the Pertonix and a 3ohm coil.
I'll test this later tonight.
Re: Ballast Wire
#14
spitfire50
Paul Mugford
Apr 16, 2018 06:31 PM
Top Contributor
Hi,
You will measure 12 V on the coil positive with the key in the run position as long as there is no ground to the coil negative. There must be a complete circuit for the ballast to drop the voltage. With no ground the whole rest of the circuit is equivalent to the positive battery terminal as far as voltage goes.
Re: Ballast Wire
#15
Voda2000
Andrew McMillan
Apr 16, 2018 06:43 PM
Joined 1 year ago
Right Paul. I meant more if after i disconnect the ballast from the white/yellow at the starter relay if I get no voltage then there is no other splices in between the starter relay and the coil.
Forums
Spitfire & GT6 · TR7 & TR8 · TR6 Tech · TR5 & TR250 · TR4 & TR4A · TR2 & TR3 · Triumph Performance · Buy, Sell & Trade · Vendor Market · Herald & Vitesse · Stag, 2500 & 2000 · Roadster & Pre-War · Odds & Ends · The Pub - Off Topic · List Archives · Motorsports · Meetup
