HOW TO ID A DIFFERENTIAL??
Dougmart Douglas Martinez
Holly Springs, NC, USA   USA
Folks
I have a spare diff that I got as part of a sale when I purchased my 72 GT6. How can I tell what ratio this diff is? Any tips or info greatly appreciated.
Thanks!
Pats54 Avatar
Pats54 Gold Member Mark M
Maynard, Mass, USA   USA
1979 Triumph Spitfire 1500
This chart will help you out by counting the teeth
IMG_2270.PNG    61.8 KB
Doug,
Hold one output shaft still and turn the other. Count the turns of the input shaft for two turns of the output. The count is the ratio. Just over 4 =4.11, just under 4 =3.89, just over 3 1/2= 3.63, 3 1/4=3.27.
mkivmarty Avatar
mkivmarty Marty Yanik
N.E.Ohio, USA   USA
Check the serial number stamped on the case. The three most common (If I remember right) are
FCxxxx 4.11-1
FDxxxx or FMxxxx 3.89-1
KDxxxx 3.27-1
Marty
Edited 1 time(s). Last edit at 2018-04-15 05:46 PM by mkivmarty.
Paul, who will get the 10,000th post?
You work hard to keep us in line, thanks by the way.
Edited 1 time(s). Last edit at 2018-04-15 06:21 PM by trrdster.
JohnW63 John Williamson
Apple Valley, CA, USA   USA
It's stamped on the bottom of the nose that extends toward the drive shaft ( Propshaft ).
Here is a link to a chart:
http://www.wolfitt.com/numbers_and_ratios.htm
In reply to # 1526536 by trrdster Paul, who will get the 10,000th post?
I guess Brendan got it. I just posted to his lowering block thread again and that was it. I didn't know until I saw your post and looked at mine in this thread. So you get the beginning of my second ten thousandgrinning smiley
Thank you ALL for your responses. What ratio will be best for a T9 5 speed conversion? I have the T9 already and seriously thinking about having it done.
Herald948 Avatar
Herald948 Andrew Mace
What's the 5th gear ratio in that T-9?
Yikes!
How do I determine what ratio 5th is on the T9?
Thanks!
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
After converting to a T9, I've only seen two ratios, 0.82 and 0.79 and both are pretty close, so probably doesn't matter a whole lot.
'S all for now
Vic
1979 Triumph TR7 Drophead
