Help! Minilite replica lugnuts!
docal Avatar
docal Alex Broumand
Los Angeles, USA   USA
Hi everyone,
I have a Spitfire MK3 1970, has steel wheels, ordered the 13x5 minilite replicas from JBW with 20 offset. got them today. The lugnuts that came with them won’t turn more than 4 rounds on the stud so the tire shop refused to put them on. The studs are basically too short. Anyone had this issue with any of the minilite replicas? Should I get new studs? Which and where from in that case? Sigh....
Advice appreciated!
Alex
Alex
1970 Triumph Spitfire MKIII, Saffron Yellow, also called ''Gullan''
docal Avatar
docal Alex Broumand
Here is a picture of the original lugnut which fits fine in the stud next to the one that came with the rim.
Alex
Alex
3AAD23F8-239D-4CF9-9AD6-E88C04513FB0.jpeg    68.5 KB
You can get longer versions of the stock 3/8-24 studs.
Or you can fit larger longer studs (many, many, MANY postings on this subject).
But then you will need a full set of new lugnuts that match them.
docal Avatar
docal Alex Broumand
Thanks Carter, appreciate it. Did some research, will probably go with the Land Rover ones.
This forum is amazing!
Alex
76HiLander Brandon G
Lafayette, IN, USA   USA
1968 Triumph GT6 MkI "The 6"
Alex, what do you think of the JBW minilite wheels? I have been looking at them and the prices seemed to be pretty good.
Thanks!
docal Avatar
docal Alex Broumand
They are beautiful! Quality seems to be great.
Alex
BEFAA10F-B460-44A7-9451-3CC2DAD9B497.jpeg    34.5 KB
Very nice! I might have to talk to the wife about a set of those!
Thanks!
SpitMan Avatar
SpitMan Silver Member Doug Walls
Brandywine, MD, USA   USA
1970 Triumph Spitfire MkIII "Lil' Red Fox"
2007 Chevrolet Silverado "Workhorse"
Hi Alex,
I have JBW Minilites on mine but was not happy with the lack of number of threads, so I put the longer M12x1.5 studs on. Check out this web link: http://auskellian.com/paul/links_files/upgrade_spitfire_wheel_studs.html
It may help.
Doug/SpitMan
turner4366 Avatar
turner4366 Tom T
Danville, CA, USA   USA
There is another conversation going on about finding longer studs. You should be able to find what you need there.
