Oil dipstick
A write up on the different types is in order.
Someone has got to have a representative sample.
Measured from the block down, what would be the depth into the sump for low and full?
Something along this line - except with numbers in the blanks spots?
IM005935-crop.JPG    41.3 KB
In reply to # 1518752 by Yellowhawk Valley
In reply to # 1518748 by Doug in Vegas Here's a question to the entire membership: Did the length of the tube in the block for the dipstick remain the same length through all years?
It looks like they use the same part number for all the engines from Mk3 onward. (Canley's at least) They don't show a tube on the 1147 engine drawing.
Dan,
My late 1147 (FC81XXXHE) has a dipstick tube. Checking the factory parts catalogue I find it listed as 121831 at the bottom of page 1 of the fourth edition. Introduced at engine FC61023 the same time as the increase in lifter diameter to 0.800" and numerous other engine changes.
I was wondering about that but the diagram in Canley's does not show one (or it is not in the same place in the diagrams as all others). ??? But that is the same part number for all the other years as well so it seems they are all the same.
philipheys Avatar
philipheys Phil Heys
Accrington, Lancashire, UK   GBR
Thanks guys,
Ok I have solved it, the one I have is round and no use whatsoever I am unsure if it is the correct part, I found one second hand on FleaBay so hopefully this will resolve my issue of unable to see the oil level.
DipStick.jpg    33.7 KB
roncohudd Avatar
Muenster, TX, USA   USA
1967 Triumph Spitfire "Lucy"
1997 Ford Ranger "Little Red"
Simple questio; simple answer. I jus need to know how many quarts does it take for an oil change. I hav5an extended tube and dipstick. I need to mark it for low and full.
TheZster Avatar
TheZster Steven Z
SAINT LOUIS, MO, USA   USA
1978 Triumph 1500 "BLK-BRY"
Sometimes the wheel gets reinvented in this forum....eye rolling smiley
Simple answer:
engine sump capacity listed at 4.75qts (with oil filter change) 4.25 qts without....
Drain your engine - put in 3.75 qts - and mark your dipstick for low level
Add another qt - and mark it for full
That should be close enough for government work.....
Z
Edited 2 time(s). Last edit at 2018-03-14 09:10 AM by TheZster.
roncohudd Avatar
Wow! Thanks
In reply to # 1518955 by roncohudd Simple questio; simple answer. I jus need to know how many quarts does it take for an oil change. I hav5an extended tube and dipstick. I need to mark it for low and full.
Like the Zster suggests, dump what you have in there and start over. If it is new, reuse, or go for new. That is by far the easiest way to mark it.
TheZster Avatar
TheZster Steven Z
HEY!! I did good, huh??
Sometimes, you guys get way to involved in slide rule stuff...... While I just drink a beer and think about the question.... LOL...drinking smiley (or think about another beer - LOL)
Actually, Carter suggested the same thing early on in this thread..... He just didn't explain it in a A/B/C type format for us technically challenged folks...
Z
Edited 1 time(s). Last edit at 2018-03-14 01:26 PM by TheZster.
1971 Triumph TR6
