Oil dipstick
philipheys Avatar
philipheys Phil Heys
Accrington, Lancashire, UK   GBR
Hi guys
I have the original oil dipstick fitted in my 73 spitfire I can't tell the oil level on the dipstick, does anyone have an alternative idea or ideas how to modify the original.
I've considered a longer tube that allows you to pull a longer dipstick from a higher location.
Andy-Sherry Avatar
Portland, OR, USA   USA
I can measure the 2 lines on my 74 dipstick then you can make small mark with hacksaw blade on yours
Andy&Sherry
1974 Spit 1500 Carmine Red
Always learning something
Voda2000 Avatar
Voda2000 Andrew McMillan
Winnipeg, MB, Canada   CAN
In reply to # 1518509 by philipheys Hi guys
My snowmobile had a hole drilled through at the high mark. Easy to see if the hole is covered in oil.
1978 Triumph Spitfire
That, or use a needle file to make grooves.
Best time is after an oil change, because you can easily calibrate it to -1 qt by only adding 3 qts, etc.
Spity Avatar
Spity John Biek
Fresno, CA, USA   USA
Here is the dipstick from my '73. Hope that helps. john
IMG_20180312_185612.JPG    23.4 KB
IMG_20180312_185518.JPG    34.6 KB
Born Loser Avatar
Land O Lake, FL, USA   USA
I am not following what you are saying. Are you saying you cant see the 2 marks? Are you saying you dont see oil on the dipstick? Or are you saying your not sure what the oil level on the dipstick means?
Matthew
1960 Triumph TR3a
1970 Triumph Spitfire MK 3
2018 Jaguar F-Pace
roncohudd Avatar
Muenster, TX, USA   USA
1967 Triumph Spitfire "Lucy"
1997 Ford Ranger "Little Red"
Does the 1147.hold exactly 4 pts including filter?
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
4 quarts?
'S all for now
Vic
Lizzard d id
san jose, CA, USA   USA
On the porsche 964 they have a gauge on the dash , you can see / read the oil level like a gas tank gauge tells you the fuel level but it being a dry sump system the reading is only good at idle , at speed it reads empty , so you can dump overboard all the oil at speed and the gauge doesn't indicate an empty . With the same sort of system on a wet sump spitfire the reading would go up and down as the oil moved forward and back , but it would be better than nothing I guess .
roncohudd Avatar
Yes qts. Duh look before sending
In reply to # 1518580 by roncohudd Does the 1147.hold exactly 4 pts including filter?
Depends on what filter you are using ...
All the Spitfire pans have the same dimensions.
I always use the large Ford style FL-1 filters with an adaptor.
Then add 3 quarts, run the motor to fill up the filter, and to check for leaks, then stop and add to the 'full' mark.
Because filters have anti drainback valves of differing effectiveness (including none at all), if you wait too long,
the reading can be up to a quart higher than when the motor is running and the filter is full.
Too much oil is bad because the oil will get aerated by the spinning crank/rods (think blender)
Too little is bad because the oil runs hotter, and is more likely to allow air to be sucked in by the pump
during 'enthusiastic' driving as it sloshes to one side in the pan.
roncohudd Avatar
Need to know the exact amount because I'm using a different dip stick. I'll mark the stick after fill and run.
Here's a question to the entire membership: Did the length of the tube in the block for the dipstick remain the same length through all years?
In reply to # 1518748 by Doug in Vegas Here's a question to the entire membership: Did the length of the tube in the block for the dipstick remain the same length through all years?
It looks like they use the same part number for all the engines from Mk3 onward. (Canley's at least) They don't show a tube on the 1147 engine drawing.
