welded door check strap bracket found
TheZster Avatar
TheZster Steven Z
SAINT LOUIS, MO, USA   USA
1978 Triumph 1500 "BLK-BRY"
Just a FYI:
I've looked through the archives - asked others... and we have all come up with zip...
My local club guru found the check strap bracket that is welded on the inside of the door frame is available at:
http://trf.zeni.net/TR6-TR250GB/index.php?zoom=1&menu=A&page=322&s_wt=1280&s_ht=720
Roadster factory....body trim and fittings - TR6-TR250 parts.....
Doesn't seem to be an exact match to photos I've seen of the spit bracket... but I'm buying one to see if it works.... It's worth $20 bucks to possibly save me a trip to a metal fabricator....
Hoping this works and will end up in the archives for others..... On the other hand - if it don't work - I'll feel pretty stupid.....
Z
I made a pair that looked just like the originals for about 3 bucks worth of steel, a hammer, vice and drill. Oh, yes, the hack saw to cut out the blank.
Not sure that one will extend out far enough but it may be ok.
If you want to prevent the door from opening so far that the door skin hits the hood you can add a strap like they put on Jeeps.
Mind you, it wont click and hold.
twomanytriumphs Avatar
Kelso, WA, USA   USA
1965 Triumph TR4 "My Baby"
1977 MG MGB
The TRF Tr6 bracket works. I put one in my gt6 before I painted it. Worked great. I found the link somewhere, I know Doug Hansen had something to do with it. Kyle.
TheZster Avatar
TheZster Steven Z
In reply to # 1512031 by Yellowhawk Valley I made a pair that looked just like the originals for about 3 bucks worth of steel, a hammer, vice and drill. Oh, yes, the hack saw to cut out the blank.
OK so I feel stupid.... TR6 bracket won't work.... way to big with wings that go the wrong direction..... back to the drawing board - and, as usual, going to have to follow Dan's advice.....eye rolling smiley
Z
TheZster Avatar
TheZster Steven Z
anybody need this bracket - just let me know.... before it goes into the trash.....
I'm fabricating/modifying the old bracket now.... actually not that difficult - with some creativity.....
Z
1978 Triumph Spitfire 1500
