spitfire transmission
jamesregis Avatar
jamesregis Gold Member Jim S
Kettering, OH, USA   USA
My transmission shifts through all 4 gears just fine, but when I try to down shift into 3rd gear It won't go and the gears grind. Any Ideas what might be wrong? My car is a 1972 model.
Assuming no clutch you must rev the engine before catching the lower gear.
Takes practice.
14GPDJENGINEERING Avatar
Silver Spring, MD, USA   USA
Broken Mainshaft snap ring.
See this: http://www.triumphexp.com/phorum/read.php?8,1511028
Dennis smiling smiley
kaatmanduu Avatar
kaatmanduu Silver Member Mike Stevens
Grass Valley, CA, USA   USA
Could be a dragging clutch too. Are you having problems with any other gears? Does it go into reverse easily?
jamesregis Avatar
Thanks Dennis, I checked out the discussion you referenced and I will check out the circlip. Jim
1980 Triumph Spitfire 1500
