67 Spitfire - Need video for Carb Rebuild
Matts67spit Avatar
Matts67spit Matt Burrow
Phoenix, AZ, USA   USA
Hello All,
I've got my 67 Spitfire carb rebuild kit ready for install - but would REALLY love a visual instruction for this, as this is my first carb rebuild.
Are there any videos/picture walk-through resources out there?
Thanks so much!
Matt
carbs - 1.jpeg    51.1 KB
carbs - top view.jpeg    50.5 KB
carbs side view.jpeg    45.3 KB
cmfisher4 Avatar
Mystic, CT, USA   USA
I did a video on replacing the throttle shafts, though your kit probably didn't come with these. If your throttle shafts "wiggle" at all, I'd recommend doing it, however. Sorry that I don't have a better video for the whole thing.
I'm at work so I can link you the YouTube video, but if you look for HS2 Throttle Shaft Replacement, or something similar, you should find it.
Again, probably not all of what you are looking for, but maybe a good idea depending on your carb's condition.
Chris
1964Spitfire Avatar
1964Spitfire Tim P
Santa Clara, CA, USA   USA
Edd China on Wheeler Dealers rebuilds a pair of SU's
Matts67spit Avatar
Thanks Tim!
gfe05111952 Avatar
gfe05111952 George Earwaker
Falls Church, VA, USA   USA
Matt, Videos aren't always available for everything you'll need to do on your car. A good manual is the first "tool" one should acquire after purchasing a car. While I have several, my go to source is my Robert Bentley manual. Not cheap, but will pay for itself many times over. smileys with beer
George
1967 Triumph GT6
1967 Triumph Spitfire4 Mk2
1968 Triumph Spitfire Mk3
Matt,
When searching for You Tube videos on carb rebuilding keep your eye out for ones by Joe Curto. Joe Is a long-time SU carb expert and explains in depth some things about the SU that are important to know.
The John Twist University Motors videos are also landmarks of the British car world.
Matts67spit Avatar
Thanks George and Paul,..watched a few videos and think I am on my way,..going to dive in!
George, I have the exact car,..spitfire4 MK2... love yours!
Working to replace the ignition switch,..will see what I get,..posting on one of my diff threads!
matt
carChips Avatar
carChips Victor Harnish
Kelowna, BC, Canada   CAN
1933 MG Magnette
Matt, do you have a picture of all the parts in your rebuild kit?
'S all for now
Vic
carChips Avatar
1933 MG Magnette
One thing that I would like to note is the main jet tube (flexy tube with a spring around) that goes into the float bowl has a little rubber seal on the end. When you take them apart make sure the seal doesn't get stuck in the float bowl opening.
'S all for now
Vic
pghponton Howard Worley III
Pittsburgh, PA, USA   USA
I think Moss Motors sells a DVD that shows SU carb rebuild process. Used to be sold on VHS, a guy in the local Brit car club still uses it!
https://mossmotors.com/mga/books-videos/repair-videos/video-su-rebuild-dvd
Regards,
Howard
1966 Triumph TR4A
