Rebuilding Air Pump
drsmod Dan Smodic
Kalamazoo, MI, USA   USA
I have a 75 TR6 and the PO had discounted the belt to the Air Pump and plug some hoses to unable the emissions setup. It's running fine but thinking of getting the car back to originality and was wondering if anyone has rebuilt their air pump. I've taken it off and did some disassembly but wanted to know more as to what I need to do.
Thanks in advance.
I've heard of people turning their air pumps into low pressure superchargers.
Other than that, air pumps are trash can fodder IMHO.
The PO likely did not remove the pump belt because the pump was not working. More likely he just did not want to waste engine power and fuel running it.
lef2wander Avatar
Hatfield, MA, USA   USA
If your looking to put it back totally original go ahead. As stated the pump is probably fine. Back in the day, alot of people blamed emissions plumping for lack of power.
In fact it was the changes to the engine itself that attributes to the lack of power. Carbs, timing, cam and low compression heads etc. If you do put it all back you will loose a little power. Not to much, however it may be noticable.
Your NA tr6 from the show room was probably around 105hp, it's euro brothers around 135hp(I think). Depending on year.
Edited 2 time(s). Last edit at 2017-12-02 12:01 PM by lef2wander.
N5329K Avatar
Pacific Grove, CA, USA   USA
In reply to # 1500783 by clshore I've heard of people turning their air pumps into low pressure superchargers.
Not in California. They keep a whole lot of Spitfires legally on the road.
Robin
Lots of teenagers have had the idea that they can turn air pumps into this:
1973 Triumph Spitfire MkIV
