Which driveshaft to use? 75 Spitfire
70tbolt Geoff Ullmann
Morgan Hill, CA, USA   USA
My 1975 in process restoration Spitfire came with these two driveshafts. One is a new universal type and the other I was told came from a GT6. The used one has new U joints installed but is missing the steel torque bands. They both appear to be the same length. Any advantages over either one?
Geoff
IMG_0728.JPG    32.7 KB
Recently someone ordered bands that failed.
Geoff, you better measure what you need, as the one on the left has no room for adjustment and the one from the GT6 has.
You can fit the newer style up and run the bolts in but pulling it together will only stretch the motor and transmission mounts. So if that is you choice, get the plates so the length will be right.
I'm thinking the strap drive shaft (as was OE on my 74) might be too long on your single rail transmission 75.
cbez Cole B
Fallbrook, CA, USA   USA
Avoid straps!!! Mine exploded. The repro ones are stamped out of a cookie sheet or something..
Loving my new driveshaft.
1971 Triumph Spitfire MK 4
Spity Avatar
Spity John Biek
Fresno, CA, USA   USA
Hi Geoff, I have the universal type on my '73. The sliding shaft makes for a perfect fit. Being skinnier it may also be a little smoother, can't think of the correct word, less mass turning, etc. John
Edited 1 time(s). Last edit at 2017-11-09 05:58 PM by Spity.
bobbylrowland bobby l
cochran, ga., USA   USA
I think I would go with the one on the right, u joints shouldn't be much more than the straps.
Geoff,
If the strap drive one has been assembled without straps the U-joints are out of phase. That will make the shaft vibrate unless it runs exactly straight. There also would be no allowance for changes in length. That will, as Wayne says, put strain on the engine and diff mounts.
BTW the idea John Biek was looking for is a lower moment of inertia.
1959 Triumph TR3A
