Rear upright for axel
Toddchris Todd Orndorff
Gettysburg, PA, USA   USA
Help need a rear upright for the axel. Anyone know where I can purchase one?
Todd what car and what side.
Yeah guess that would help!! 73 spitfire drivers side.
I'll see what I have tomorrow, in the meantime maybe someone else has one handy.
Ok thanks, just let me know.
79bluespit Avatar
79bluespit Rick Lazio
Burlington, ON, Canada   CAN
73... was a transition car has the longer axle shafts... check yours as yours could be a 72 titled as a 73. i have avail for the 62-72 models.
Could you send a picture. The part I need also has a grease zirc for the bearings
The part I am looking for is connected to the end of the axle and has the rear bearing in it. Can not locate it in moss catalog? Would appreciate any help locating it
Edited 2 time(s). Last edit at 2017-11-07 10:10 AM by Toddchris.
Todd, that is a different animal than you initially asked for.
I'll look at the warehouse, but I think most of mine have the axle attached and I don't have the puller right now.
You might have more luck just buying the whole thing, then change out the bearings.
In fact, I think I did sale the last pair I had about a month ago.
I'll still look, it's the hub carrier you want..
In reply to # 1496409 by 79bluespit 73... was a transition car has the longer axle shafts... check yours as yours could be a 72 titled as a 73. i have avail for the 62-72 models.
Does not matter what the title says, only matters what's actually bolted onto to the car.
Short/long axles are easily swapped back and forth, both by those who don't know the difference and those who do.
It's not unusual to find cars with a mixed set, usually you cannot tell when driving the car normally.
2manyspits Avatar
2manyspits Thomas Schlundt
south bend, IN, USA   USA
If you cant find one i have several make me an offer
Thanks every one for all your help. Also Wayne thanks for identifying the particular part I need. Unfortunately I should have waited for Scotts offer before ordering from Moss.
1977 Triumph 1500
