Floppy Visors
Floppy Visors
  This topic is about my 1966 Triumph TR4A
ducbsa Bruce Metcalf
Berryville, VA, USA   USA
My original white visors were falling apart, so I wanted to replace them and found out that they aren't available except from Skinner. I decided to try TR6 visors. Their hardware doesn't fit a TR4A, so I used the existing hardware, which worked pretty well, except that the visors wouldn't stay in place. I tried squeezing the steel tube with smooth jaw channellocks, but that didn't work. I came up with using 1/4" bore shaft collars, with a longer bolt that I bent to provide a handle. I made the bend to put the "handle" at just the right angle when tightened. I clipped off the bolt heads and put on plastic thread protectors. I hope these pix show it clearly enough.
Edited 1 time(s). Last edit at 2017-10-19 04:10 PM by ducbsa.
visor a.jpg    30.6 KB
visor b.jpg    31 KB
Geko Avatar
Geko Stef SG
you could have just bent the rods slightly and then insert in the tube
1973 Triumph GT6 MkIII
