Front Suspension Shims
  This topic is about my 1966 Triumph TR4A
ducbsa Bruce Metcalf
Berryville, VA, USA   USA
I rebuilt the upper front suspension and replaced the rack before having the front end alignment checked last year. I replaced the lower bushings this spring and took it to the alignment shop and I need to add a shim to the left lower side
and take one out on the right. I see that shims come in just one thickness, so it looks like I can just swap them side to side and take it back for a check. Any suggestions? I'd like to do it just once since it will require removing the springs. I have a compressor, so it isn't tough, just a lot of work.
1967 Triumph TR4A
