Rear leaf springs
Andy Saltspringer Avatar
Andy Saltspringer Andy Higgs J
Saltspring Island, BC, Canada   CAN
Hi
I am cleaning up my rear leaf springs; a shackle has broken and they neededto be painted and re-bushed.
On assembly I would like to know if they need to be reradiused, unfortunately they were off the car when I bought it so I cannot measure an ladened dimension. Currently center eye to center eye is 40". The workshop manual quotes 41" ladened so do I to assume that they are probably in pretty good shape?
Does anyone have an unladened eye-to-eye measurement from a set of rear springs that are known to be good?
Any help greatly appreciated!
Andy
1961 TR3A
1946 Harley Davidson WL45
1960 BMW R60/2
1972 BMW R60/5
1973 BMW R75/5
1981 Moto Morini 500
Randy C Avatar
South Ogden, UT, USA   USA
You might consider calling the Roadster Factory's customer service number and ask them what the measurements are of the new rear springs that they sell. In the past I have found them to be helpful answering technical questions.
ArtL Avatar
ArtL Art Liefke
Kings Park, NY, USA   USA
I have a pair of new aftermarket (from Moss) TR3 leaf springs sitting in my garage. They measure 40" center of eye to eye. However, these are the notoriously stiff springs with "208636" (part number) stenciled on with white paint. The leaves measure thicker than OE. I haven't installed them because of that.
Art
208636 is the TR4 part number, supposedly interchangeable with the TR3 springs. But I had the same problem with them being way too stiff with the ones I got from TRF some years ago. The free height was about the same as stock springs, but I measured the rate at 220 lb/in, much stiffer than the 128 lb/in given for stock springs or even 155 for competition springs. The result was totally undriveable, as the axle spent most of it's time pressed against the frame.
I've since heard that TRF fixed their problem, but haven't tried another set myself.
All good advice; I heard that the aftermarket springs were pretty questionable and they lacked the taper seen in the ends of the original springs, which resulted in a harsh ride and odd ride height.
It sounds like my springs might be pretty good so I am going to refurbish them and see how they look.
I took delivery of my engine components yesterday and now have about six cardboard boxes sitting on the floor of my workshop containing all the overhauled parts. The block was cooked and washed, the corrosion removed, liner lands cleaned, refaced and then hot washed again. Crank, head and block magnafluxed. The liners were honed, new figure eight gaskets supplied, pistons cleaned up and pistons and rods balanced, crank balanced and polished, new unleaded exhaust vale seats fitted, head decked, valve guides sleeved and honed, valve springs checked for tension, flywheel surfaced and balanced. Camshaft checked and new camshaft bearings fitted. New journal and mains supplied, new rod bolts, new piston rings, crank machined for the modified rear main seal. The whole bill was $2,250US so Christmas came a bit early...
My workshop now has a 1946 WL45 Harley in pieces, a 1973 R75/5 in the middle of a major service, and a 1961 TR3A in bits... Not a great deal of counter space available....
Andy
1961 TR3A
1960 BMW R60/2
1972 BMW R60/5
1973 BMW R75/5
ArtL Avatar
ArtL Art Liefke
In reply to # 1501499 by Andy Saltspringer ...
My workshop now has a 1946 WL45 Harley in pieces, ...
In the late '70s, I acquired a 1946 WR45 in exchange for a 100cc Bridgestone dirt bike. It was in pieces and I had to put it back together. It came with a Wico magneto in the place of where the generator normally resides, and had no brakes. I installed a rear disc brake from a Honda. I got it running and ride-able, but really needed to get a generator and distributor to replace the magneto to run some lights. I traded it for a Kawasaki 500 triple. One of my more stupid moves.
Art
MGB777 Avatar
MGB777 Tim Smith
Oregon, IL, USA   USA
1952 MG TD "The "Abbey"
1960 Triumph TR3A "Patch's"
1975 MG Midget 1500 "Little Bro"
1977 MG MGB "Big Brother"    & more
There are spring repair shops still around ,,,,,,,, have a set made to your specs. A couple of years ago I had some re-arched for another project . Then another time I had a broken leaf replaced.....maybe all those "too stiff" sets you guys have can be fixed ?? ,,, just my .02
JoeOtero Avatar
Lexington, KY, USA   USA
1963 Triumph TR3B
1968 Triumph GT6 MkI "Cali"
1971 TVR Vixen
1972 TVR Vixen
In reply to # 1501541 by ArtL
Kawasaki 500... Oh my!!
Back in the day (high school) I had one.. I ported and polished the top end (ports and top of the pistons were like mirrors when I finished..) Oh what a beast it was when I finished it.. Wish I kept it.. So much work and I'm sure the next owner did not appreciate it... Was hell on handling.. But in a straight line.. hard to beat.. Dang.. Thanks for the memory!
Joe Otero
1979 Triumph Spitfire
