Jaejer Speedometer and Tach parts interchangeable?
TapTR360 Orlando T
Little Rock, AR, USA   USA
Would anyone know if the 62-TR3A (same year/make of guages) needle bearing/drag wheel on the tach can be used a donor for on a speedometer? Both tach and speedo seem to be identical mechanical design.
CJD john durant
Southlake, TX, USA   USA
I suspect they are. I know they indicate the same needle deflection at the same input rpm...at least for the standard 3:70 gears. The casing is identical, but I have not checked to see if the drillings were made in the tach casing to accept the odometer mechanism.
Southlake, TX
'55 TR2
TapTR360 Orlando T
Thanks! That will be a great relief in only having to get one rebuilt. As far as I can tell side by side comparison they are identical.
1964 Triumph TR4
