TR8 Transmission Mount question
johnjb John B
Auburn, WA, USA   USA
1980 Triumph TR8 ~ For Sale ! ~
I am in the process of replacing the transmission bushing and thought while I'm at it I might as well replace the transmission mount.
Ordered one from the Wedge Shop and then read an article in the 2014 TWOA Spring Newsletter about problems with replacement transmission mounts.
Seems the problem described has to do with new mounts not fitting well, Hard rubber and creating problems (noise) ---have there been any updates since this article?
My old mount is worn, but not creating any problems.
Any suggestions, comments would be appreciated, thanks John
johnjb John B
Auburn, WA, USA   USA
anyone out there with some experience on this subject?
darrellwalker Darrell Walker
Vancouver, WA, USA   USA
1966 Triumph TR4A "Christy"
1981 Triumph TR8 "Kate"
I believe the situation is still the same, the reproduction mounts are still quite hard. There are some suggestions about a Volvo mount that can be adapted, but the one I bought seems about as hard as the reproductions. But if your mount is failing, you really don't have a choice.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
acltpvd charles frink
Mass, USA   USA
Re tranny mount.
IF IT AIN'T BROKE DON'T FIX IT
sliproc Avatar
sliproc Kevin Quistberg E
Long Beach, CA, USA   USA
Charles,
That's normally sage advice, but as with all British car owners we keep fixing things until they're broke.
In reply to # 1518979 by sliproc Charles,
LOL! spinning smiley sticking its tongue out
bowen6951 Avatar
Fontana, CA, USA   USA
Hi Vance,
when I was putting my car together that article came out, so I put in the Volvo. Just had to enlarge the mounting holes and add a couple washers for it to fit. Is it better (?), don't know the car was in pieces when I bought it. Thanks, Rob
P1060176.JPG    38.8 KB
NJ, USA   USA
What is the part number for the Volvo mount?
dmtrmp6 Daryl M
FADDEN, ACT, Australia   AUS
Ross, John et al,
Believe the Volvo mount is very similar in design and requires only minor changes as mentioned above to install. It is common across a variety of Volvo installations for petrol & diesel with both manual and auto transmission. A good breakers yard may provide or following are some details for new source. Quick check on the 'bay returns price range from $30 - $100 depending on source.
Gearbox Mounting (rear) Volvo 740/940 - 2.3L I4 - Manual (740 760 940 960)
Volvo part number: 1328900
A/mkt Pt No: Febi 05041, Mackay A7406, and possibly LR2617
Refer attached photograph. Rgds, DM
volvo mount for tr7 5 speed pt no 1328900.jpg    33.3 KB
bowen6951 Avatar
Hi Ross,
here is the site and the part number that I got. I purchase here as it is a genuine Volvo part and not something from India. Thanks, Rob
Rubber cushion...Part Number: 1328900...$ 61.98
https://www.volvopartswebstore.com/products/Volvo/Rubber-cushion/1106787/1328900.html
Edited 1 time(s). Last edit at 2018-03-17 05:59 PM by bowen6951.
johnjb John B
Auburn, WA, USA   USA
Just a follow up on this subject
I did order and receive the transmission mount from the Wedge Shop
And it is hard as a rock---will take the old one out and see what shape it in.
John B
sbs Avatar
sbs Steve S
One of the mounts tested in the TWOA reference was the Bilstein version, which was reported to be good.
It's hard to find in the US but common in Europe. Here's one place I found over here:
https://www.fcpeuro.com/products/volvo-transmission-mount-febi-bilstein-1328900
johnjb John B
Auburn, WA, USA   USA
I order the Volvo transmission mount and the rubber is just as hard as the stock one.
1971 Triumph Spitfire MkIV
