help with a part hose TR7
jb4249 Avatar
jb4249 Ted Bush
Highland Heights, USA   USA
I am unable to locate a heater hose I need, UKC 4457. Goes from the hot water choke outlet to the manifold. Any help out there?
Ted
mcmahontr7 Chris McMahon
Fort Worth, TX, USA   USA
I see the hose in the new Victoria British catalog for $8.95. Also, I believe Rimmer Bros has it.
Chris
In reply to # 1508450 by jb4249 I am unable to locate a heater hose I need, UKC 4457. Goes from the hot water choke outlet to the manifold. Any help out there?
Ted
Doesn't look like anything special. Have you tried getting some plain heater hose from your FLAPS as a replacement?
Many of the molded hoses on my TR8 are NLA, but can easily be replaced with standard heater or emissions hose from a local auto parts store.
If you have something that makes a sharp bend and wants to kink, you can insert a spring from the local hardware store before installing it. That way it won't kink and it will look molded.
Your choice.
jb4249 Avatar
jb4249 Ted Bush
I didn’t try Rimmer but called Victoria, TRF, BPNW, and finally Woody at the wedge shop. No luck. I ordered a hose from the local parts store with a 90 I it and will fit it tomorrow. I may try the spring trick for the rest of the bend.
Hope to do initial startup tomorrow.
Thanks, Ted
1976 Triumph TR6
