TR8 top hose
Bergie Bob Berg
Powell, OH, USA   USA
Folks ..I heard back from McKay Rubber in Australia and they do have the longer version of the Triumph TR-8 top radiator hose I had them create some years ago...when you use an aftermarket intake manifold-edelbrock, wildcat, willpower the thermostat housing sits differently than the OEM set up and you need more length at each end so you don't kink the hose...Part number CH 5702...cut to fit. .....Likely available from Europe auto parts distributors or McKay website.....I also add a stainless steel spring to the 160 degree bend at the thermostat housing to keep it from deforming...
Sent: Thursday, October 19, 2017 2:43 AM
To: Robert Berg
Cc: Shane Anderson <>; Lee Taylor <>
Subject: RE: Hose Availability
HI Bob,
Yes, both are available, however I don’t recall any of the US Triumph specialists stocking the new design.
Region Make OEM # Mackay # Notes
UK TRIUMPH GRH628 CH4277 GRH628 OEM# Replacement - See CH5702 for Aftermarket Inlet Manifolds
UK TRIUMPH GRH628-LONGER CH5702 Mackay's Longer Version of GRH628 to suit Aftermarket Inlet Manifolds
Can you send me a list of Triumph specialists in the US, and I will send them out a pricelist and see if I get any interest in someone stocking them.
Will Paton
Product Specialist, Automotive
d. +61 3 9276 4680
p. +61 3 9555 6500
Mackay Consolidated Industries Pty. Ltd.
260 Chesterville Road (PO Box 1113) Moorabbin Victoria 3189 Australia
mckay hose.jpg    17.2 KB
POW Peter Wirth
Is this something Rimmer Bros. may supply?
1973 Triumph Spitfire 1500
