TR5 & TR250 Forum
Unusual Relay or Switch
TR5-2085 Jim Fitzpatrick
Allen, TX, USA   USA
I'm slowly getting my TR250 back up and running I'd welcome any suggestions about, what appears to be, a relay. It has 3 terminals, it was mounted above the hazard relay, and it was disconnected from any vehicle wiring.
distinguishing marks - it has markings on the side and near the 3 terminals -
side markings - T B P
Connection face TR BATT PUL(?)
Attached are a few images - all suggestions appreciated.
Jim
IMG_1210.JPG    48.9 KB
IMG_1216.JPG    43.5 KB
IMG_1217.JPG    42 KB
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
Jim, that is likely the overdrive relay. I don't have one on my TR since it doesn't have an overdrive but looking at the manual, that's where the overdrive relay would reside.
gozto11 Avatar
gozto11 Todd Bermudez
Cincinnati, OH, USA   USA
While I don’t have a picture to prove it, that’s surely aftermarket.
I have a 250 with overdrive that I took apart. It has the standard relay mounted above the horn relay(I believe) on the left inner wing just in front of the wiper motor
Allen, TX, USA   USA
You're right, the relay was mounted where I'd expect to find an overdrive relay but it looks aftermarket and there's no evidence of an OD having been fitted, (gearbox is regular 4 speed, there's no OD switch on the steering column). So it's a relay that likely controlled some other aftermarket piece of equipment, but what? And there's no evidence of an aftermarket AC having been fitted...
It would be interesting to find out what it controlled and I suspect someone's seen a similar, 3 terminal, relay.
Thanks for the suggestions.
Bpt70gt Avatar
Bpt70gt Brian T
It will probably remain a mystery.
mgruber921 Avatar
mgruber921 Marvin Gruber
Florence, AL, USA   USA
Some PO add on, not even a Britiish relay. Looks to be an even older than the car relay. Maybe for aftermarket horn.
Marv
1974 Triumph Spitfire MkIV
