TR5 & TR250 Forum
1968 TR 250 original emissions lines
1956 Avatar
1956 Jeffrey Lampinski
Media, PA, USA   USA
Hi folks,
I'm looking for the original metal (looked like mini hydraulic) emissions lines that were installed on the U.S. model 68 GT6. Mk 1 (pictured below as items 6 and 9). I'm posting here because they also appear to have been on the 68 TR250 and possibly the early TR6. They ran from a banjo bolt on the inlet manifold to by-pass valves on each CDSE carb, and also to a vacuum control valve. Hopefully someone has them in a dusty old box somewhere!
Thanks.
Jeff
Late Edit: I was informed the TR250 setup was slightly different than the GT6. I'm still interested in any TR 250 lines. Perhaps I could work them to replicate the GT6 setup.
Edited 1 time(s). Last edit at 2017-09-09 07:43 PM by 1956.
gt6early_plate_m.jpg    46.8 KB
TR250Guy Avatar
TR250Guy Tim Moore
Dayton, OH, USA   USA
The GT6 system is different from the TR250 system. As you can see 6 and 9 in your diagram are different than the 50 and 52 in the TR250 diagram.
1968 TR250 "TRminator"
Owned since 1980
TRS-020.jpg    49.6 KB
1956 Avatar
Media, PA, USA   USA
Thanks Tim. If any are out there I may still be interested. I may be able to modify them to reproduce the GT6 arrangement. I'll change my original post.
Jeff
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
If someone has these pipes and don't want to part with them, if they could give dimensions to the bends and lengths, I'm sure these pipes can be reproduced.smiling bouncing smiley
1956 Avatar
Media, PA, USA   USA
My thought also, especially so if the pipe diameter is the same as traditional hydraulic brake line. Thanks, and good thought. Jeff
1972 Triumph GT6
