TR5 & TR250 Forum
TR250 to TR5 conversion almost complete
hans48t Shannon McMullen
, , Canada   CAN
I've almost completed the conversion . Engine, tranny are in. Static timing still has to be set, metering unit timing set, LHD P.I. accelerator pedal mounted, bosch pump along with new aluminum TR5 fuel tank (with PRV and metering unit independent returns, swirl chamber and baffles)
Here are a few pics...enjoy
10550924_10202474341619704_2653288573722178308_n.jpg    45.8 KB
10898149_10202474337819609_5014528925901968644_n.jpg    38.3 KB
1505156_10202474339259645_4506692239993632731_n.jpg    44.6 KB
HuffDaddy Avatar
HuffDaddy Scott H
Charlotte, NC, USA   USA
1976 Triumph TR6 "Huff Daddy"
Shannon,
That is an awesome project. I love the TR250's, but to make it into a TR5 with PI will be a jolt. Keep us posted. You are going have a great spring and summer driving that bad boy.
, , Canada   CAN
Thanks very much. She has been full of surprises along the way but I'm looking forward to cranking her up in the spring/ summer.
maddmapper Avatar
maddmapper Ken Prentice
Victoria, BC, Canada   CAN
Nice, very nice. Have to keep us posted once you get her on the road.
On a side note, you went against common convention with the black engine bay. I kinda lean the same way as I prefer to have the engine bay black (it's black in my white TR6) rather than the same colour as the car. Anyone else have their engine bay black?
Edited 1 time(s). Last edit at 2015-02-09 03:46 PM by maddmapper.
atgordon Anthony Gordon
Wilmington, NC, USA   USA
In reply to # 1264986 by hans48t I've almost completed the conversion . Engine, tranny are in. Static timing still has to be set, metering unit timing set, LHD P.I. accelerator pedal mounted, bosch pump along with new aluminum TR5 fuel tank (with PRV and metering unit independent returns, swirl chamber and baffles)
Great job ... I did a PI conversion on my 72 TR6 a few years back but could never find a LHD PI pedal. Where did you find one? It's almost academic since the RATCO TR6 accelerator linkage will do a fine job for both carbs or PI unit.
It looks like you have the metering unit worked on: I'm guessing you upgraded to unleaded seals.
ATG
chris Avatar
Pendleton, OR, USA   USA
Sweet!
Member Services:
Used English car parts.
, , Canada   CAN
There's a beast under that hood
12307420_10204073623960763_7193111173611915909_o.jpg    46.4 KB
Michelotti Avatar
Michelotti Brad B
Marietta, GA, USA   USA
A beast living free from the 1968 EPA rules that tamed the rest of us running dual Zenith Stromburgs. I bet its a blast driving a TR-250 rocking the performance motor it was designed for. Well done!
, , Canada   CAN
Yes, my friend, it is.
triumph74tr6 Avatar
triumph74tr6 Chad Jester
Tulsa, OK, USA   USA
1968 Triumph TR250 "Gene"
1971 Triumph GT6 MkIII "Ken"
I've passed up some otherwise very good cars due to a blackened engine bay.
In reply to # 1265052 by maddmapper Nice, very nice. Have to keep us posted once you get her on the road.
salvy66 alan salvatore
SC, USA   USA
In reply to a post by On a side note, you went against common convention with the black engine bay. I kinda lean the same way as I prefer to have the engine bay black (it's black in my white TR6) rather than the same colour as the car. Anyone else have their engine bay black?
The Triumph engine bay came painted body color. GM engine bays are painted black.
Painting a Triumph engine bay rattle can black is the fastest way to depreciate the value of your car.
Generally the quick tip off of an econo non-original re-spray; along with painted door latches.
But, as they say, its your car.
eye popping smiley
Al
mgruber921 Avatar
mgruber921 Marvin Gruber
Florence, AL, USA   USA
Not a fan of black engine bays. Looks like a chevy
Marv
, , Canada   CAN
I agree. The black engine bay came like that when I bought the car.
In 3 years I'll be doing a tear down and complete body will be sprayed with correct royal blue color. Unfortunately, work is getting in the way at the moment.
Stampy Avatar
When i do get to my engine bay it will be painted a contrasting light colour to my body colour.
The purist in me says stick to the stock red on red. But the car guy in me says do it in Ford 9N tractor grey engine bay with the red.
My dad had a 9n and it was so cool to drive when your 7.
Scott
Edited 1 time(s). Last edit at 2017-07-24 11:43 PM by Stampy.
IMG_1455.JPG    86.2 KB
Bpt70gt Avatar
Bpt70gt Brian T
Westmoreland, NH, USA   USA
That will be interesting.
1970 Triumph Spitfire MkIII
