Stag, 2500 & 2000 Forum
Can anything be done to reduce diff whine on a Stag?
sujitroy Avatar
sujitroy Sujit Roy
Cupertino, CA, USA   USA
I've been told by a diff shop that there is nothing much that can be done to a diff to reduce the whine.
However, someone said adding poly bushes to the rear suspension reduced the noise.
I've heard from earlier posts that new crown and pinons were not great. However, one or two folks say this is not the case anymore.
The same guy at the diff shop said that there is no way of telling, without installing it on a car, if a diff is any good. This guys worked with a Welch guy for 22 years working on diffs.
Anyone on this forum had any experience?
California, USA
Sometimes you can tell they're bad without installing. Should turn silky-smooth by hand, no resistance or tight spots or gritty feeling.
But otherwise I agree, running it at speed under load is the only way to prove that it's good. There's probably a way to do that on the bench, but building the setup would take longer and cost more than just putting it in the car.
Might be worth trying this stuff. Won't solve the problem obviously, but might help reduce the noise. (I've heard it helps, never tried it myself.)
1974 Triumph TR6
