Herald & Vitesse Forum
Getting the rear reflectors off?
Dadsturn Avatar
Dadsturn Platinum Member Ed M
Cicero, NY, USA   USA
Doing body work and stripping the car down. How do you get the triangular reflectors from above the taillights off? I don't see a nut on the back of the threaded stud that sticks thru and into the body.
1964 Herald 1200 Convertible
1966 Chevy Bel Air
Got it covered. A Land Yacht and a Dingy!
quikrx Ralph Hansen
Antioch, IL, USA   USA
1962 Triumph Herald 1200
1987 Mazda RX-7 "Mistress"
gently pry them away from body, should have a clip into the body - can also try squeezing the clip inside the cavity and pushing it out - both have worked for me
Dadsturn Avatar
Cicero, NY, USA   USA
Thanks Ralph. (Forgot to ask you last time we talked)
1966 Chevy Bel Air
Herald948 Avatar
Herald948 Andrew Mace
ISTR that clip is a spire nut or fix nut and looks something like this?
Sometimes you can get a small drift on the end of the pin and gently tap; on the other hand, those fix nuts can be quite tenacious!
Dadsturn Avatar
Cicero, NY, USA   USA
Thanks Andy.
1966 Chevy Bel Air
