Motorsports Forum
Toyo Proxes R888 - "flopping" ok?
Spitfirejoe Avatar
Spitfirejoe Joe Guinan
Fremont, NE, USA   USA
Got a free used set of 185/60 R13 Toyo Proxes R888's for my Spitfire. The outside edges are worn quite a bit more than the inside edges - which seems pretty normal for a road race tire. The question is - Can I mount these tires on opposite sides of the car to even out that wear pattern. The tires are prominently marked "Right" and "Left" and are definitely uni-directional. Swapping the left side tires to the right (and vice versa), but maintaining the direction of rotation would help me get some more time out of these so I could do some test and tune and track days on free tires. I think I'd get new tires for actual races next season, but I'd like to use these for practice if I can.
I found a Miata site on which someone said "flopping" the tires as I want to do is completely "OK" according to a Toyo engineer. It even said you could run them in opposite rotation direction as long as it was a dry track - that the directional grooves were simply provided to channel water away from the contact patch. See this link - http://forum.miata.net/vb/archive/index.php/t-40734.html
What do you guys think?
Joe Guinan
Fremont, Nebraska
Proxes.jpg    9 KB
Will you use these mainly on the street or the track?
Some directional tires are built with asymmetrical carcass and tread (Acura NSX tires)
but if these are just tread I think you are OK.
I'd run them and see.
Edited 1 time(s). Last edit at 2016-08-26 08:50 AM by clshore.
TR4racer Avatar
TR4racer Mike Deweerd
Woodstock, Ontatio, Canada   CAN
Not a problem to do so. I switch tires from side to side between race weekends to even the wear and get the most out of the tires.
Keep them on the track!!
Mike
Spitfirejoe Avatar
Yeah - this will be car that only runs on the track. Thanks, guys. I was hoping to get confirmation that this practice with these tires would be OK. I should be able to get several track days out of a set, or maybe a weekend race. I think I have a continuing supply of these, which will really help on the budget.
Joe Guinan
Fremont, Nebraska
1976 Triumph TR6
