Front Valance
ptaylor Peter Taylor
Ottawa, ON, Canada   CAN
I want to replace the front valance on my 1971 TR6. Do I need to remove the front fenders first ?
gozto11 Avatar
gozto11 Todd Bermudez
Cincinnati, OH, USA   USA
I believe so as the front wing headlight bits will be in the way. I'm pretty sure the bottom 5 bolts screw from the engine bay side thru the valance into the outer wing
Todd
triumph74tr6 Avatar
triumph74tr6 Chad Jester
Tulsa, OK, USA   USA
1968 Triumph TR250 "Gene"
1971 Triumph GT6 MkIII "Ken"
Yes. The fenders need to come off. There are a ton of spot welds you won't be able to access with the fenders on.
It isn't too bad a job. Just make sure to trial fit your front fenders back on before final welding to make sure you have the valance properly positioned.
Chad in Tulsa
Are you serious??...Did not realize that either the fender or the valence was welded on ??
gozto11 Avatar
Valance spot welded...outer wings...not
Todd
OK...Thanks for the info...going to have to rethink this project as I don't do welding....lol
triumph74tr6 Avatar
Tulsa, OK, USA   USA
Yep....the valance is 100% spot-welded on.
Just an FYI...you will need to remove the headlight buckets to access a hidden bracket on each front wing.
I have a valance off right now....could post some pics if you'd like to see how it attaches.
Chad in Tulsa
Great...any pics would be helpful.
lesgilholme Les Gilholme
Newman's Cove, Newfoundland & Labrador, Canada   CAN
Hi im about to replace my front valance...do you still have pics? lesjangil@hotmail.com
modelafish Mike Mc
Nampa, ID, USA   USA
I know it's an old post, but since it's already there........
Add one more that needs to replace the front valance. Met a guardrail last year that I didn't like.
My valance appears to be welded to the inner panel all the way around. What's the usual way of taking apart ? AIr chisel ?
I figure an HF wire feed welder will do the job reattaching.
Any tips would be appreciated.
IMG_0548.JPG    32.3 KB
dsixnero Avatar
dsixnero Dan Colanero
Westville, NJ, USA   USA
Did you guys see the price of a front valance? over 800$ I have a good front body tub in my shed, maybe I should remove the valance and sell it. Dan
1937 Triumph Dolomite
