Engine work needed
Krom Avatar
Krom Paul K
San Rafael, CA, USA   USA
Larry- if you don't take thorough care of the bottom end, you'll always wonder (at best), or wish you had (at worst).
NHinNC Avatar
NHinNC Larry C
Greensboro, NC, USA   USA
Engine block plugs: Steel or brass?
EDIT: I did not give my question properly. Should I replace with brass or steel? Brass ones are quite a bit more, and are they worth it?
Purchased July 2015
Edited 2 time(s). Last edit at 2018-05-19 08:55 PM by NHinNC.
dicta dick Taylor
In reply to # 1534275 by NHinNC Engine block plugs: Steel or brass?
Check with a magnet.
Dick
