Oil leak continued
Doctorfloss Robert K
Frederick, MD, USA   USA
I wanted to upload another photo. The silver canister is connected to this pump directly above it. Can oil leak from here??
7CED896B-3879-4FC1-811D-4144654B505D.jpeg    46.3 KB
chris Avatar
Pendleton, OR, USA   USA
It can from between the fuel pump and the block, but you look clean there.
Member Services:
Used English car parts.
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1974 MG MGB
1976 Triumph TR6
1980 MG MGB
Robert - You seem to miss the point of discussion "threads". You start a topic and receive responses as well as add more of your own thoughts, observations, etc. Starting a new thread for each new thought defeats the purpose of a thread. Especially for anyone trying to search the past for information on a topic.
Thank you for the clarification. Going forward I will try to keep that in mind.
mk21965 Avatar
mk21965 Stuart Brainerd
Stony Creek, CT, USA   USA
The fuel pump body has a vent on the crankcase side of the fuel pump diaphragm so if it leaks it runs out instead of filling the sump and diluting the oil. You can see the small hole just above the lever in your pic. If there is enough crankcase pressure you can get some leakage from there.
1981 Triumph TR7 Drophead
