Black paint
NHinNC Avatar
NHinNC Larry C
Greensboro, NC, USA   USA
I am going to paint the rocker panels and the rear valance black. I have looked at other posts, and they say SEM flat black.
The Rocker panels would be black below the chrome strip; easy.
The rear valance, I'm not so sure about. Does the rear of the trunk lid also get black? under the bumper is also body color? Where is the line for that?
Purchased July 2015
Sapphire Avatar
Sapphire Walt P
York, PA, USA   USA
Here's the rear paint on my '72.
1972 CC80594U Sapphire Blue
DSCF1136 (2).JPG    44 KB
DSCF1135 (3).JPG    39.4 KB
DSCF1137 (2).JPG    30.5 KB
DSCF1138 (1).JPG    44.6 KB
spridgettr Avatar
spridgettr William Kern
Pittsburgh, PA, USA   USA
and the above pics are how it should be.......but some folks do it all the same as body
Casey808 Avatar
Casey808 Casey S
Honolulu, HI, USA   USA
1969 Triumph TR6 "Adèle"
In reply to # 1510526 by NHinNC I am going to paint the rocker panels and the rear valance black.... The rear valance, I'm not so sure about. Does the rear of the trunk lid also get black? under the bumper is also body color? Where is the line for that?
Follow this factory painting guide for the Rear Valance appliqué - drinking smiley
Keep 'em on the Road! Cheers!
TR6 Rear Boot Paint Guide.jpg    28.8 KB
Triumphgt6er Avatar
Triumphgt6er Jim Snell
Cave Creek, AZ, USA   USA
1974 Triumph TR6 "Bubbles"
In reply to # 1510526 by NHinNC I am going to paint the rocker panels and the rear valance black. I have looked at other posts, and they say SEM flat black.
Think SEM Trim Black is a better match....kind of Satin.
https://www.eastwood.com/trim-paint-satin-black-aerosol-15-oz-net.html?gclid=Cj0KCQiAzMDTBRDDARIsABX4AWwpTNDlOQFZOM6Rk4P44STzcgWRzn6XswY6cjXhG9B0PKN5HP-fa48aAv9BEALw_wcB
NHinNC Avatar
NHinNC Larry C
In reply to # 1510548 by spridgettr and the above pics are how it should be.......but some folks do it all the same as body
The DPO only painted with body color. I already fixed behind the front grill. The Mimosa shining through the grill looked stupid. I fixed it, before I even knew what I did was what it came out with.
Purchased July 2015
NHinNC Avatar
NHinNC Larry C
Thanks for the diagram and the paint tip.
Purchased July 2015
ng19delta Avatar
ng19delta Scott Roberts
Merchantville, NJ, USA   USA
LOL... Again, I used Tractor Supply "Majic" brand matte black on mine...
Scott
mhbva Avatar
mhbva Marc Botzin
Lorton, VA, USA   USA
1976 Triumph TR6 "Monty"
The rocker panels were not paint but 3M body schutz. A type of rubberized and textured coating intended to protect from corrosion and provide sound deadening. The only issue is that it requires a special gun to apply because it is so thick. I would think that spray undercoating would be a closer match than paint if you don't want to go through the trouble and expense.
NHinNC Avatar
NHinNC Larry C
I used Flex Seal on my front wheel wells 2 years ago, and have found that to work well. It is still stuck on, no peeling. Some of the black (original?) coating had worn off from the tire, as the shocks were shot, exposing a good sized area of original green paint. This *might* be OK for the rocker panels, but it is more of a eggshell or semi gloss sheen, so I would not use it on the rear.
Purchased July 2015
TRroadster Don S
edmonton, AB, Canada   CAN
Do you have one for the front?
NHinNC Avatar
NHinNC Larry C
In reply to # 1511305 by TRroadster Do you have one for the front?
One of what?
Purchased July 2015
TRroadster Don S
black paint diagram/guide.
Sapphire Avatar
Sapphire Walt P
York, PA, USA   USA
In reply to # 1511620 by TRroadster black paint diagram/guide.
This photo shows the front black out area.
DSCF1134 (1).JPG    50.4 KB
TRroadster Don S
Thanks Walt.
1965 Triumph Spitfire MkII
