timing
timing
GDL412 Garry Loomis
Granville, NY, USA   USA
Set timing at 12 degrees BTDC, retard vacuum doesn't work. set my idle little high, rpms fluctuate 1000 to 950 rpms. Any suggestions? thanks garry
mhbva Avatar
mhbva Marc Botzin
Lorton, VA, USA   USA
1976 Triumph TR6 "Monty"
Not seeing why you would want the idle to be set higher than 850, but you may want to set or check your timing by vacuum reading to 17-18 inches. In my car, I can get the car to idle as low as 500 rpm although it is a lot smoother at 850.
dicta dick Taylor
In reply to # 1494889 by GDL412 Set timing at 12 degrees BTDC, retard vacuum doesn't work. set my idle little high, rpms fluctuate 1000 to 950 rpms. Any suggestions? thanks garry
Garry --- Is the engine speed fluctuating, or just the tach needle?
Dick
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1974 MG MGB
1976 Triumph TR6
1980 MG MGB
You don't address plugging the vacuum line to the distributor. It must be well sealed at the carb/manifold.
dsixnero Avatar
dsixnero Dan Colanero
Westville, NJ, USA   USA
Gary, I have a different cam and I'm at 14 btdc and between 900 and 1000rpm.Goes down to 850 when the e-fan comes on.
1964 Triumph Spitfire
