Announcements Archive
Post your car in the Triumph Experience Registry!
Skye Avatar
Skye Webmaster Skye Nott
Vancouver, BC, Canada   CAN
1964 Vespa VNB 125
1966 MG MGB "The Bomber RIP"
1983 Suzuki MC GS750E "Kate"
1986 Merkur XR4Ti "The Rally Car"    & more
Just a reminder to post photos of your ride in the registry & vote for your favorites!
Thanks! Skye grinning smiley
Webmaster, The Triumph Experience
Member Services:
Building the best online communities for auto enthusiasts
mntr463 Avatar
mntr463 Pat Bob
Mpls, MN, USA   USA
1963 Triumph TR4
1980 Triumph TR8 "The Eight"
I also had a oil leak from my new spin on so i sent your question to our chat forum. This was a good reply
I just put one on my TR3B. I did not use any sealent. There is a rubber gasket just like the one you used on your drop in cartridge. They give you about 4 gaskets, I chose the one not too fat and not too skinny. Are you sure there isn't an old gasket still stuck up in there?
Anyway, the gasket, then the aluminum adapter, then there is a little O-ring, 1 1/2 inch, put that in, then the thing that goes into the center hole, what your spin on filter threads to.
Put the old filter on, and do not over tighten.
If I were you, I'd just redo it. Clean it all well. Follow the instructions. When you are done, you should not need sealent, and it shouldn't leak. (You'll have plenty of other oil leaks, but not from the filter assembly.)
Good luck.
Steve
1967 Triumph TR4A
