Spitfires List Archive
U-joint replacement
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: Matthew Milkevitch <(email redacted)>
Fellow Listers;
I hope everyone had a pleasant New Year's.
At present, I am finishing up a differential swap on my '77 Spit. Glad it's
almost done.
While bolting everything up, I noticed that the u-joint on the driver's side
half-shaft is coming out of the yoke about 1/8" on one side.
I assume this u-joint will require replacement. I have replacement units on
hand.
Question: How easy is this repair? I have not done any work on axles before.
Any advice would be appreciated!
Best Regards,
Matt Milkevitch'77 SpitfireWillow Grove, PA
Support Team.Net team.net/donate.html
(email redacted)
autox.team.net/mailman/listinfo/spitfires
team.net/archive
mailbot Avatar
Mail From: "Jim Muller" <(email redacted)>
> driver's side half-shaft is coming out of the yoke about 1/8"
> on one side. I assume this u-joint will require replacement.
It sounds like one of the retaining clips came out or broke or rusted
away. You need at least to replace the clip but you should replace
the joint anyway.
> I have replacement units on hand.
Depends on how hard it is to remove the bearing shells from the
yokes. The last time I tried it they were stuck pretty good and I
didn't have a good enough press or a big enough hammer. But in
theory it isn't hard.
You'll need to take the axle out of the car, and if you can't finish
the job you can just take the axle over to a shop that can do it for
you. Even if you just do that you may have saved some labor cost.
One possible issue is that the clips which came with the u-joint may
not be the exact thickness. If they are too thin it can allow slop
which will introduce vibration. A shop will probably a collection so
they can pick on that fits. Also fit a grease nipple.
I'm sure someone here has better advice.
Jim Muller
(email redacted)
(email redacted)
team.net/archive
mailbot Avatar
Mail From: "Doug Braun" <(email redacted)>
My bit of advice: you may think that you can replace a u-joint from under the car with the axle in place, but it isn't worth trying. Accept the fact that you will have to disconnect the brake line, etc and completely remove the axle/hub assembly.
Doug
(email redacted)
team.net/archive
