Spitfires List Archive
Rear Wheel Stud Removal
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: "Daniel Parrott" <(email redacted)>
Now that I have the Canley Classics CV joint-axels in, I cranked on the rear
hubs. When I added the road wheels to the frame (to get the rolling chassis
really "rolling") if find that for some reasons none of the wheel studs will
tighten, the threads are too small. I need to replace the wheel studs at
this point for both of the rear axles. However, how does one actually
remove the wheel studs on a hub that is already installed? I have a
Churchill tool, but if the studs are so buggered up that they won't hold a
tire on, I'm sure that the Churchill Hub Puller (also from Canley Classics)
won't do the trick. Is there a special tool or technique? I tried to
hammer the stud to no avail.
TIA
Dan Parrott
Savannah, Ga
1980 Triumph Spitfire "PJ"
1972/1978 Spit Six Project car "Joseph"
Support Team.Net team.net/donate.html
(email redacted)
autox.team.net/mailman/listinfo/spitfires
team.net/archive
mailbot Avatar
Mail From: "Joe Curry" <(email redacted)>
If they are the stock studs, there is enough clearance between the hub and
backing plate for the studs to be removed. All you have to do is knock them
back with a hammer and remove them from behind.
Joe
-----Original Message-----
[mailto:(email redacted)] On Behalf Of Daniel Parrott
Sent: Sunday, December 27, 2009 4:15 PM
To: 'Spitfire list'
Subject: [Spits] Rear Wheel Stud Removal
TIA
Dan Parrott
Savannah, Ga
You are subscribed as (email redacted)
(email redacted)
team.net/archive
(email redacted)
team.net/archive
