6Pack TR6 List Archive
Update on my Hayden fan saga
mailbot Avatar
mailbot Mail List Archive Bot
The Interwebs, USA   USA
Mail From: Joe Honor <(email redacted)>
I successfully established a workaround to bypass both relay and radiator
thermostat to have now simple 20a simple on/off switch for fan/ works ok what
are my downsides to this ie no relay no fuse/which I could easily patch in
Regards Joe
(email redacted)
Donate: team.net/donate.html
Archive: team.net/archive
Forums: team.net/forums
mailbot Avatar
Mail From: (email redacted)
Joe,
I would not leave it on the switch. If it doesn't go through the key, it will stay on and kill the battery. If you forget to switch it on and miss the high gauge reading you can overheat.
I can't imagine that you have another bad set of t-stat & relay. Check the wiring in common. I believe that you should be able to short the connections from the t-stat on the relay and it should activate.
Lou
72 Pimento
------Original Message------
Sender: (email redacted)
To: TR-6 list
Subject: [6pack] Update on my Hayden fan saga
Sent: Aug 24, 2010 9:35 PM
Regards Joe
(email redacted)
Unsubscribe/Manage: autox.team.net/mailman/options/6pack/(email redacted)
(email redacted)
1970 Triumph GT6 MkII
