voltage gauge question
  This topic is about my 1978 Triumph TR8
uspsmech Avatar
uspsmech Jim F
North Providence, RI, USA   USA
1978 Triumph TR8 "007"
Looking for advice or opinion on a minor issue I've never noticed before
Started my 1978 TR8 with stock Lucas alternator and original voltage gauge today
I noticed at startup the ignition light was on and voltage needle at extreme left of gauge
It took roughly twenty seconds for the needle to get into what I consider a normal range,( the light went off almost instantly after startup)
At the battery I have 12.75 volts at idle, unfortunately nobody around to rev the motor while I check meter
Am I looking at a problem or is this lazy needle just something I've never noticed before?
I did remove the ground from alternator bracket to shock tower and clean all contact points thinking it could be a weak ground
That really had no effect
Thanks for any opinions or advice,
Jim
" Enjoy the Drive", Jim
darrellwalker Darrell Walker
Vancouver, WA, USA   USA
1966 Triumph TR4A "Christy"
1981 Triumph TR8 "Kate"
My needle is also lazy, and I've been told that is normal. I don't know why Triumph decided to heavily dampen the motion of the volts gauge, while having the fuel level and water temp be super responsive.
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
uspsmech Avatar
uspsmech Jim F
Thanks Darrell, that makes me feel somewhat better. Spend my time fixing problems that are actual problems
In reply to # 1601655 by darrellwalker My needle is also lazy, and I've been told that is normal. I don't know why Triumph decided to heavily dampen the motion of the volts gauge, while having the fuel level and water temp be super responsive.
The voltage gauge is thermal, not electromagnetic. So it takes a few seconds to reach equilibrium. This is done to reduce noise sensitivity. The temperature gauge is similar in its operation.
In reply to # 1601731 by Darth V8R
Hi Vance,
I agree the volts gauge is thermal (bi-metallic strip). But the fuel level and temp gauge are both electromagnetic. If they were bi-metallic, then they would need a voltage stabilizer like the TR4A (and I think TR6). The volts gauge of course doesn't need stable voltage since it is measuring voltage.
Volts gauge on the top, fuel level and temp on the bottom.
Darrell Walker
Vancouver, WA, USA
IMG_0592.jpeg    27.1 KB
IMG_0593.jpeg    25.8 KB
In reply to # 1601824 by darrellwalker
Hi Vance,
Darrell:
All the gauges except Oil Pressure are thermal in the TR6. I ASSUMED (and we know what means) that the TR7 was the same.
Another perfectly perfectly reasonable assumption blown to hell by data. I hate it when that happens! angry smiley
TR8Craig Craig B
Johnstown, PA, USA   USA
At idle shouldn’t the battery voltage be about 14 volts? The 12.75 seems low to me.
uspsmech Avatar
uspsmech Jim F
Actually had time today to revisit the "non" problem today.. With car off, battery measures 12.01 volts. After initial startup, fast idle, measured 13.5 volts. At 2000 rpm, 14.11 volts. Fully warmed up, slow idle 12.85 volts. The needle on the gauge seems much less lethargic with the warmer weather. Now if only I could fix the elusive oil leak as easily! Thanks to all for the help and or advice,Jim
TR8Craig Craig B
Guess I need to check my Triumph. Memory tells me my MG battery voltage is about 12 with engine off and 14 at idle. Hopefully Lucas isn’t playing with me.
1980 Triumph 1500
